Hooking up fuel pressure gauge
I have a 03 cummins. I want to hook up my pod gauges. Only one left is the fuel pressure. I have an air dog 150 lift pump and was told you can plug right into that, but the harness from the gauge doesn't match the plug of the lift pump. Wondering if anyone out there knows of a harness to plug both into or another solution to making it work. Thanks
put one of these in your fuel line, just make sure you install in between your last filter and your CP3. XDP Push Lock Fuel Pressure Tee XD200
I ordered my sensor from ebay and it came with the harness to plug in the sensor, I then had to run wire from it to the edge harness for my guage. I also have the fass 150, I put my sensor in the fass unit ,and it works great.
SENSOR, FUEL PRESSURE, 0-30PSI, 1/8" NPT MALE
WIRE HARNESS, PRESSURE, DIGITAL STEPPER MOTOR, REPLACEMENT
No, I did not use my stock filter, I actually asked one of their techs about doing that, and they did not recommend doing that. I know there are members that have used the factory filter with no problems, I guess its up to personal preference.
EverydayDiesel
06-18-2007 04:31 PM
