Hmmmm. DTT trans issue..
Old May 21, 2006 | 05:39 AM
Dodgezilla's Avatar
Unhappy Hmmmm. DTT trans issue..
Lately I've found that if I do a really hard pull on the street, I start to smell burning fluid and I get some fluid dripping from the inspection plate under the bellhousing. I pulled the plate off and the converter itself is dry so it must be coming from somewhere else. The temp guage doesn't show that it's getting hotter than normal and the fluid leak pretty much goes away if I go back to driving like normal. I will still have a drip every couple of days but that may just be residual. It's not a whole lot of fluid that comes out, maybe a 1-2" puddle, but it definitely concerns me.
It's been a while since I built a trans but I remember that there used to be a vent on the pump at the front of the trans. I'm wondering if somehow I'm getting too much internal pressure at full throttle and that's causing fluid to come from that vent?!?! Other than that, all I can think is a bad pump gasket or pump seal where the TC goes into it. It seems like if it was one of those two, that it would leak all the time.
Any ideas????
Old May 21, 2006 | 08:07 AM
masonic-dodge's Avatar
Your tranny over-flow is inside your bellhousing, I'm does the same thing.
CRIS
Old May 21, 2006 | 09:34 AM
Mike D's Avatar
Too much fluid? Right Cris..
Dodgezilla's Avatar
Hmmm, so you are saying that maybe I have too much fluid in there??? Sure would be nice if that's all it was. Problem is that it did it before and after my new filter change. Hard to believe Tim and I both overfilled it......
Old May 21, 2006 | 10:25 AM
BarryG's Avatar
Did you get the upgraded drum? If so that may be it. Bill has told me that after a hard run they can do that but nothing to worry about. I would give him a call though.
Old May 21, 2006 | 10:30 AM
Mike D's Avatar
Might be worth a check.. It has happened to me too. I put too much fluid in after a filter change one time and it leaked out the vent. I would get the fluid hot and see how much it shows on the stick.
Old May 21, 2006 | 10:38 AM
Mike
Thats funny but true, why don't you update your sig.
CRIS
Old May 21, 2006 | 10:52 AM
Tfeore's Avatar
After I upgraded tranny and TC I get a little puddle after every hard pull with the toy hauler. Was told it was the from the vent tube also.
Tom
Old May 21, 2006 | 11:01 AM
Dodgezilla's Avatar
Cool! You guys are making me feel better.. Yes I got all the bells and whistles and drums and shafts and ...........
Thanks for the replies.....
Isn't the internet great!?!?! Just think how much needless money we would all spend trying to find simple problems like this.....
Old May 21, 2006 | 11:19 AM
Mike D's Avatar
Originally Posted by masonic-dodge
Mike
CRIS
Which part? Dyno numbers or the addition of billet shafts?
ckennedy
13
Sep 29, 2004 06:46 AM
westcoaster
Jan 20, 2004 02:32 PM
AKDSLDOG
Mar 18, 2003 12:18 AM
TPilaske
16
Nov 6, 2002 03:26 PM
