Highest EGT witnessed on your own truck
Old Mar 27, 2009 | 01:34 PM
  #46
mulisha's Avatar
yeh you know,i had the edge to and the egt's it said were a little off compared to a needle gauge that i installed.also performance tests were wrong also, proved it at the track.its just not the most accurate.
Old Mar 27, 2009 | 05:09 PM
  #47
LFD2037's Avatar
Originally Posted by 2007 5.9
How do you figure that my pyro is installed incorrectly or faulty or that I dont push on it hard enough???
Just because I designed and built my air/fuel system appropriatly and use the right Smarty settings so that I dont have high EGT's somehow I did something wrong??
I dont see your logic or methood.
I never said you don't push it hard ENOUGH. However far YOU choose to push it is hard ENOUGH. I just don't see how your EGT's don't get above 1200 unless you don't go WOT or you have never towed a decent amount of weight. It really is nothing to get upset about.
Old Mar 27, 2009 | 05:47 PM
  #48
BSouth's Avatar
About 1525 crankin on er with the old juice on 6.
Old Mar 27, 2009 | 05:55 PM
  #49
mudder500's Avatar
bluechrome said he seen 1900 a few times
Old Mar 27, 2009 | 06:00 PM
  #50
AH64ID's Avatar
I rarely see over 1200 with my Jr, I have to either be really lugging it at altitude on a hot day, or working it above 2500rpm up a big hill on a hot day... The Jr just does a good job, so I could see how conservative towing could make 1200* your max..
What do you see with your Jr?
Old Mar 27, 2009 | 06:12 PM
  #51
LFD2037's Avatar
10K lb. 5er thru the 'hills' in central Teaxs I see about 1350 & that's being easy on it w/jr. on SW2. When my RPM's are up, it stays cool. When the TC is locked & lugging is when it gets hot.
Old Mar 27, 2009 | 06:16 PM
  #52
CD in NM's Avatar
1400* plus a little pulling 20K loaded trailer on a 6% grade for about a 10 minute total in 101* ambient air temperature in 5th gear at 65mph.
CD
Old Mar 27, 2009 | 06:23 PM
  #53
AH64ID's Avatar
That sounds to me like your either on TM3 or TM1 with Jr Revo, or your pyro isn't working properly... When my dad tows 10K from Washington to Montana and back down into Idaho (Lots of Rocky Mountain Passes) he doesn't even get up to 1350*.
Old Mar 27, 2009 | 06:44 PM
  #54
LFD2037's Avatar
Honestly, I was really cornfused about the TM settings @ the time. We shall see what it is now that I have the TM #'s figured out(thanks to you I might add!)!
Old Mar 27, 2009 | 06:46 PM
  #55
AH64ID's Avatar
No problem.. If you were running 3 or 1 you will be surprised at the drop with 2 or 4 (4 is the biggest drop, but the smokiest)
Old Mar 27, 2009 | 07:45 PM
  #56
LFD2037's Avatar
I thought you were talking about the torque mgmt. I think it was 3 because 4 covers my 5er in soot!
Old Mar 27, 2009 | 08:45 PM
  #57
AH64ID's Avatar
ahhh.. 3 runs almost as hot as stock, try 2.
Old Mar 27, 2009 | 09:31 PM
  #58
Shagginwagon's Avatar
1400* briefly when on the dyno with JR stacked with EZ, both on 3.
Old Mar 30, 2009 | 09:09 AM
  #59
Neight's Avatar
It just touched 1450* towing 6k up a long grade.
Old Mar 30, 2009 | 10:53 AM
  #60
BIGDAN65's Avatar
did some runs the other day and hit 1600
