Help with simple question
Old Dec 15, 2005 | 06:20 AM
TAS05CTD610's Avatar
Pillar
Not sure on the pilliar as I have the triple mount. Both gauges have there ups and downs. Electrical, such as tranny temp, or the pyro, has a sending unit that has wires that run to the unit, very easy and nice. Some things are mechanical, like the boost gauge (most people mix what they have) it really depends on what the gauge is vs. mechanical or not. You can't get a mecanical EGT gague (unless it mounts on the manifold) I've never had problems with either, for what you get there very worth the money. I have the diprocl, pics in gallary, and I love them. Hope this helps some
Old Dec 15, 2005 | 06:25 AM
donnee's Avatar
I have the Issopro boost and pyro gauge on a pillar mount on mine and am vey pleased with them.
Either the Diprocol or Issopro match the newer dash.
The choice is up to you.
Old Dec 15, 2005 | 06:51 AM
MikeyB's Avatar
You can install a combo gauge (boost/EGT) from Westach for the SRT-10 mount. It's not a perfect match to the factory gauges but it's close enough for me. You can see a pic in my photo gallery.
MikeyB
Old Dec 15, 2005 | 09:13 AM
firestorm's Avatar
MikeyB
Same here, I modified my 3-pillar to accept 4 gauges. there are pictures in my gallery. All but the Oil PSI, and boost part, are Westach electrical.
Old Dec 15, 2005 | 11:42 AM
05HDRAM's Avatar
I have Isspro gauges, and am very satisfied. I don't have the part numbers, but they are easy enough to find on the web.
I would recommend getting a boost bolt, makes installation a breeze. Only other items I remember were splices to tap for power, and extra wire to lengthen the trans temp wire to the sender.
Old Dec 15, 2005 | 12:28 PM
TRAVIST's Avatar
I have the di pricols and love them in the cubby hole.
Old Dec 15, 2005 | 12:46 PM
Bad Ramer Jamer's Avatar
Here's my ISSPRO'S.
Oop's. I see Travist beat me to it. How did you get that pic approved so fast.
Old Dec 15, 2005 | 05:15 PM
underwoodtransp's Avatar
I have the autometer ultralite ones in my 3 gauge pod in my photo gallery. They match very close to the factory ones... brushed alum surrounds with a brushed alum face almost looks white and the red needles to boot. I second the boost bolt but I have no idea what you need for the fuel pressure gauge.. I don't have one.
Old Dec 15, 2005 | 05:19 PM
P.J's Avatar
P.J
Originally Posted by jumpinj
I am leaning toward the issopros: now just left is to get a price for it all. We have good guages we now need cheap price. Great
Check here:
www.dieselmanor.com
Treated me right.
Old Dec 15, 2005 | 05:40 PM
hognutz's Avatar
isspro guages are what I would go if you want to go mechanical.
I tend to like electric guages better as to ease of install though. not sure which comeout cheaper after you buy the isolator for fuel pressure and all that. autometer makes some white faced electric gauges but I am not sure at night how close the match would be. I have seen pics of the isspro and they look close. Diprocol boost gauge just looks jacked up. the gauges look like they match good other than that though.
if you want 4 gauges logical choice for you would three gauges in the cubby and one in the srt-10 pillar if you want your grap handle. if you don't want the grap handle you could use a different pillar.
Old Dec 15, 2005 | 06:06 PM
If you're considering exhaust and a air intake system, now would be a good time to buy them if you can afford it. Diesel Manor, and all the other vender's will give you a package deal.
