Help with shock absorbers
Old Sep 18, 2007 | 09:45 AM
whitetrash66's Avatar
Hey
after stacking my lift and spacers, my shocks are too short. I got longer ones in yesterday.... how hard are they to install?
Old Sep 18, 2007 | 10:34 AM
ptgarcia's Avatar
Pretty easy to do. Remove the lower shock bolt then unbolt the shock tower and pull both out through the engine compartment. Unbolt the shock from the tower, bolt on the new one, then drop the tower and shock back into place. Bolt on the tower then fasten the lower shock bolt.
Old Sep 18, 2007 | 10:40 AM
rustyshakelford's Avatar
here my little take on it because even though i have huge guns, compressing the 5100s is hard by yourself at the angles you work in.
when installing the new ones, i dropped them down and bolted the bottom first. then i went back and tightened the shock tower up. i then cut the strap keeping them compressed and guided it up thru the hole on the shock tower. it worked for me...if you look at it, you should see what im talking about!
brett
Old Sep 18, 2007 | 10:47 AM
ptgarcia's Avatar
You must be a girly man.....
Old Sep 18, 2007 | 10:49 AM
WUnderwood's Avatar
the fronts are a pain, the back ones aren't that bad, if you have a helper
Old Sep 18, 2007 | 10:59 AM
ok college boy...did harvard not teach you to work smarter not harder? you must have been to busy surfing and doing keg stands out in calli!
i graduated from the school or hard knocks and i got my g.e.d. at that. im from the streets homie
brett
Old Sep 18, 2007 | 11:01 AM
cbrahs's Avatar
rite on bro! lol. LMAO!!
Old Sep 18, 2007 | 01:44 PM
Grocery Getter's Avatar
I did my all alone. Its not that bad. The one "problem" area for me was the nut on the top of the front shocks. Just tightening or loosening this allows the shock stem to turn. For the stock shock removal, I gave it a hit on the impact gun and was sucessful. Installation, I had to use a "gearwrench" and a hex bit with a ratchet to keep the stem from turning.
Question... The front shock towers. Do they need to be installed in a paticular position or can the tower be rotated from the factory installed position. Does turning it 90 or 180 degrees matter? I didn't see any difference in position. Just the front right shock seems to be angled slightly forward.
Old Sep 18, 2007 | 01:48 PM
nope.. they are the same...as long as everything lines up your good to go...
that was my experience, but some on here think im a "girly man" so take it with a grain of salt....
also the person calling me that drives a manvan if that says anything
brett
Old Sep 18, 2007 | 02:18 PM
paroxysym's Avatar
rears are easy. the fronts can be a bit of a pain since you have to remoce the coil to get to them.
Old Sep 18, 2007 | 02:27 PM
what are you talking about? no you dont! if you did, then you went to way to much work!!
brett
Old Sep 18, 2007 | 02:29 PM
WUnderwood's Avatar
you dont have to take the spring out, just take the tower off, 3 13mm nuts I think
hope this helps
Old Sep 18, 2007 | 04:42 PM
SSminnow's Avatar
Ouch. You should have asked before you went through all of that
Old Sep 19, 2007 | 07:04 AM
paroxysym's Avatar
eh i replaced the coils with lorenz anyway at the time...
redneck1
Sep 15, 2005 09:25 AM
johnr9q
Aug 29, 2005 07:35 PM
wcbcruzer
May 19, 2005 09:53 AM
John_P
Jul 2, 2004 09:40 AM
Tackdriver
Dec 15, 2002 12:19 PM
