Help with SB 3250 DD
Old Mar 19, 2009 | 11:06 PM
Smalz's Avatar
I have a 2006 with a 3250 DD. Just lately when I start in 2nd gear there is a sound like the clutch is slipping. I also fell it in the pedal. If I start in 1st nothing. 12,000 miles on the clutch. Have not hooked anything behind her yet to see if it holds the weight but what to you guys think. It has always jumped a little when backing up and made 2 very different sounds one at idel with the clutch out and one with the pedal in. Almost like a bearing out. I need some advice please. Thanks
Old Mar 20, 2009 | 10:05 AM
mxg342's Avatar
The sounds you are hearing at idle are normal for a DD clutch. With the pedal out, it's the intermediate plate rattle. With the pedal in, its the two discs slipping between the intermediate plate.
I'm not sure what you are refering to as a sound of the clutch slipping when pulling out. Are you're RPM's jumping without picking up any more speed?
The DD clutch does make all kinds of noises. It's something I have learned to live with. And people at toll booths really look at you funny too!
Old Mar 20, 2009 | 10:49 AM
CrazyCooter's Avatar
Mine growls on light takeoffs while unloaded. Is this what you speak of?
Old Mar 20, 2009 | 11:35 AM
Easy_C's Avatar
If its sounds almost like a rubbing sound your clutch just has a light glaze on the ceramic buttons from not being abused. My friend had that and called south bend and they told him to be really hard on it a few times. IE holding the brake while letting the clutch out so it will slip and then pushing it back in before over heating it, let it cool down. Rev up in 3rd gear and dump the clutch... stuff like that
Old Mar 26, 2009 | 01:28 AM
pupeperson's Avatar
Mine does the same things. I've found that in reverse the secret is to rev the engine a bit and slip the clutch some. Otherwise it's grabby enough at low rpm to make the truck jump around quite a bit. The real problem is that reverse in the G-56 is too high geared! A big-rig type high numerical reverse gear would be a big help.
diggity dodge
Jun 9, 2010 04:58 PM
rstone
23
Oct 17, 2007 07:58 PM
CTD03
Sep 5, 2007 11:03 AM
jmccart
14
Jul 17, 2007 05:21 PM
bridleman
0
Jun 24, 2007 12:59 PM
