Help! 17" aftermarket wheels on '05-'06??
Old Aug 20, 2005 | 09:52 PM
UnrulyNFS's Avatar
I encounterd one site that someone mentioned caliper clearance problems on the '05-'06 for 17" wheels.
BigCustomWheels.com for the 17x9" Moto Metal 951's1.
"(774x245mm). Big Hub. Bolt pattern: 8x165 (8x6.5). Offset: -20 to 20 mm. Tires up to 824x295mm. Rims up to 26x10.0".>>>>>> *Brake caliper issue with 17`` aftermarket<<<<<<< "
Man, I could use some input on this one.
Help!!
NFS
Old Aug 21, 2005 | 01:09 AM
pullin hard's Avatar
unless some thing changed big time with the brakes, they should fit no problem
Old Aug 21, 2005 | 09:01 AM
SolarRam's Avatar
I am running the MOTO Metal 951 in a 20" and have no problems at all.
Did you use the whell size guide on that site?
Here is what I came up with using this site.
Click Link
Old Mar 16, 2009 | 10:19 AM
sallyman1's Avatar
so basically -6 offset will make the same tire stick out further than a +10 offset?
Old Mar 16, 2009 | 12:29 PM
enafzige's Avatar
I know with KMC wheels, some of the XD 17" series fit and some don't...it just depends on the design of the wheel.
--Eric
roughstock
Nov 2, 2013 01:48 PM
Nick & Kels 08
Jan 12, 2011 06:14 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
