Guage Mounts
Guage Mounts
Has anyone found a decent looking set up for two guages mounted in the dash, on the dash, or on the a-pillar in a 2003 2500? I don't particularly feature having to cut off the handle on the post and I have shift on the fly so there is no room in that area. Thanks.
Just ordered an SRT 10 pillar from Genos. Has a single gauge opening and is a factory part. Also ordered a dual Westach gauge for both EGT and Boost. Its an option vs looking for a mounting for two seperate gauges. I personally did not like any of the multi mounts out there.
I bought the Westach combo gauge and pillar pod from Geno's Garage. $199 for the gauge and $29.50 for the pod.
The Westach came with the thermocouple and Geno's throws in a boost bolt. The boost bolt replaces one of the intake manifold bolts so you don't have to drill for the boost pickup.
MikeyB
MikeyB
check these out for an 03
quadzillapower has a mount for 2 or 3 gauges that will mount under the radio in the cubby hole
tst has white gauges that change at night like the orginal
http://www.quadzillapower.com/guages.htm
also http://www.tstproducts.com/gauge_kits_trial.htm
TORQUE BEAST
Feb 2, 2009 06:15 PM
bigragu
Jan 24, 2006 11:16 AM
