Good news on the G56 clutch replacement
I just got word that 80 pcs. of the solid flywheels for our single disc clutch are off the production line and in route to us. 100 more to follow. About 1 1/2 weeks to our door. This kit will replace the dualmass flywheel and self adjusting pressure plate. The clutches will be offered in the same configurations we offer now...CON O, CON OFE, CON FE. We made the flywheels to eliminate the needle roller pilot brg. All the flywheels will have a roller ball brg. installed. We have also made in mass production new pressure plates to our specifications. We have taken the clamp load up to 3400 lbs. Stock was 2850 lbs. and modified was 3150 lbs. Now at 3400 lbs should offer a higher torque capability. These pressure plates will fit all of the 13" upgrades for the 5sp (nv4500), all the 6sp (nv5600) as well as the new G56. 3000 pressure plates are in production and should start hitting our door in the next few weeks.
Peter |
Thanks for the update Peter
