-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   Gear Vendors Overdrive on NV5600 (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/gear-vendors-overdrive-nv5600-60927/)
yannick Feb 10, 2005 11:25 AM
Just wondering if anybody is running these tranny "splitters" on 600's with the NV5600.
Very pricey add on but with a 22% reduction in RPM when engaged this sounds like a major fuel economy advantage when towing (with a 3.73 rear the engine should be about 1800 rpm at 70 MPH). Not to mention how cool it is to have an 11 speed truck!
Any feedback would be great! Thanks:D
RustyJC Feb 10, 2005 11:39 AM
If you're going to be using an exhaust brake as your signature indicates, you might want to consider the U.S. Gear unit for the NV5600.
Rusty
Agades Feb 10, 2005 11:40 AM
how much torque are these units good for
will they hold up on a hopped up truck?
yannick Feb 10, 2005 11:49 AM
Rusty, Cure my ignorance again...Why is US gear better for exhaust brakes?:confused:
RustyJC Feb 10, 2005 11:59 AM
Because the Gear Vendors unit is a re-engineered Laycock overdrive such as one would see on Austin-Healeys, Triumphs, MGs, etc. It does not like to be "reverse driven" - that is, it works fine when the engine is driving the rear wheels, but it is prone to slippage when the rear wheels are driving the engine (such as when an exhaust brake is in use). You either have to disengage it when using the exhaust brake or wire the exhaust brake such that it can't engage when the GV unit is activated.
The U.S. Gear unit was originally designed by Doug Nash using parts from the Ford T&C (top-loader) 4 speed. It's an all-mechanical unit that doesn't have any exhaust brake restrictions.
Rusty
Scotty Feb 10, 2005 12:47 PM
Correct me if I am wrong here...The Gear Vendor cannot be used in 4 wheel drive correct?
I doubt it would be a big concern for most people. However, If I have to run in 4x4 for some reason, it might be nice to have an extra higher or lower gear option in that circumstance too.
Scotty
Haulin_in_Dixie Feb 16, 2005 09:56 PM
Scotty the US unit bolts between the transmission and the transfer case, thereby usable in 2 or 4wd. It is also stronger than the other unit, it has a much heavier load rating.
Mopar_Mudder Feb 17, 2005 08:54 AM
This has been discussed a bunch. As I remeber it would take around 300,000 miles for the overdrive to pay for itself in mileage saving. Not worth it.
bluepp Feb 19, 2005 08:23 PM
Also as I understand it ,the gear vender is installed on the rear diff only . So when you go into 4 wd you must dissingage the overdrive, and run stock ratio.;) ;)
J&L Feb 19, 2005 08:37 PM
Look in issue 47 on page 162 , latest issue of TDR mag, for a article about Gear Vendors/US Gear. The best article I've read on the pros/cons between the two. The article is Dodge specific as the author is using '02 6spd. Need to read........JIM
Raspy Feb 20, 2005 11:01 AM
One nice feature of the Gear Venders is it's designed to shift at full throttle. You split the gears without letting off at all. The US Gear can't shift till the power is off. But the US Gear can be used at any speed from rock crawling on up and the Gear Venders doesn't work till it has enough speed to generate oil pressure. The US Gear is probably more efficient because it's not hydraulic. Tough choice. If all you want is a higher gear and don't need the splitting, it may be better to go with taller tires.
Wetspirit
