GDP install help!
Old Sep 26, 2006 | 11:05 AM
acook's Avatar
GDP install help!
I tried to start the buildup of everything on my truck last night and started with the GDP GFS392. The sender(i think) on top of the tank, the one in between the two fuel lines has a connection that i cant seem to get off no matter how hard i pull. I pulled the red safty and im trying to push down on the tab but it just wont pull out?? Also should i just set it up to run max pressure instead of what it comes set as?
Old Sep 26, 2006 | 11:07 AM
Pooter's Avatar
Good info, with pics, and how to set the valve...
http://www.glacierdieselpower.com/im...rf-Install.pdf
I wouldnt run max pressure unless you need it, id just run 18-20, or whatever is recommended unless you are putting a larger turbo, etc on the truck, just because stock fuel pressure is pretty low...(people seeing as low as 5-6psi when they installed a guage)
Old Sep 26, 2006 | 02:13 PM
acook's Avatar
ok what about the connection on the tank? Im installing my twin turbos to, so should i set it up higher?
Old Sep 26, 2006 | 02:25 PM
lmills's Avatar
Don't know what to tell you on the connection. It should just come right apart. As for the pressure, regardless of airflow 20 psi should be fine for a mild set up, but more would not hurt. As needs increase, just bump the pressure up.
That's the nice thing about the walbro. Plenty of headroom. I have mine set at 55 psi right now.
Old Sep 26, 2006 | 02:32 PM
banshee's Avatar
I responded to the connection question in the other post....
Old Sep 27, 2006 | 10:26 AM
RockcrawlingTJ's Avatar
Check here for instructions on those connections.
http://www.innertruck.com/ventkitinstructions/
Old Sep 27, 2006 | 12:49 PM
acook's Avatar
Big help, thanks alot.
Roperteacher
Mar 4, 2008 08:17 PM
BRT
Feb 4, 2008 01:04 PM
Megacab07
Oct 21, 2007 08:18 PM
CTDinMT
Jul 15, 2007 10:12 PM
BossHogg
Apr 12, 2007 12:51 AM
