Gauges, Gauges, Gauges, lets see them.
Old Dec 4, 2007 | 01:39 AM
Kman9090's Avatar
I need to buy a gauge pod but don't know where to put it so far I am liking the dash tripple mount with a 0 60 pound boost gauge and pyrometer, then a quadzilla rail pressure gauge to go along with it but if anybody could show me ehat they have going on I am running out of ideas because of the attitude being in the way.
Old Dec 4, 2007 | 05:37 AM
RamWheelsBy4's Avatar
Here are my 5 standalone.
Old Dec 4, 2007 | 07:15 AM
Foxborough's Avatar
I like mine in the overhead, but I olny have two gauges.
Old Dec 4, 2007 | 03:11 PM
Kman9090's Avatar
I like the ones in the cubbyhole on the dash panel but kinda out of my view point, not sure if I would pay to much attention to it. The ones above the mirror look cool but I haven't found one that just holds 2. Where did you get that at? How hard was it to wire everything up there? I was also looking to mounting the ones on the dash. I just need two gauges another pyrometer and a mechanical boost since the edge doesn't go high enough.
Old Dec 4, 2007 | 04:41 PM
Foxborough's Avatar
I got the whole kit from Dieselmanor, very helpfull. http://www.dieselmanor.com/pillars_p...uge_mounts.asp It wasn't very hard to do the wiring either. I just hated drilling & tapping the manifold, brand new truck and putting holes in it . Getting the wires to stay up in the headliner. I used some super glue for weatherstrip. The instruments slide in from the front, I used pinstripe tape to make the gauges tight. Geno's garage also has gauges. Dieselmanor has instructions to download from the wesite under resources. Good luck deciding, lots of choices.
Old Dec 4, 2007 | 06:43 PM
homewrecker's Avatar
I like the steering column pod.
Old Dec 4, 2007 | 09:17 PM
Kman9090's Avatar
That looks like it would get in the way a little bit??
Old Dec 4, 2007 | 11:35 PM
Danavilla's Avatar
One advantage of the dash mount is that they are within line of sight when you're driving. You can see them with just a glance down. With bifocals, that helps.
Dan
Old Dec 4, 2007 | 11:44 PM
rufushusky's Avatar
Old Dec 5, 2007 | 12:24 AM
beachmstr's Avatar
I like the ones in the cubby hole but I don't think it will fit in the 07 will it?
Old Dec 5, 2007 | 08:15 AM
jrussell's Avatar
Nope, it doesn't fit with the '06-'07. You would have to make your own and it will only hold 1 gauge...
Old Dec 5, 2007 | 08:54 AM
donnee's Avatar
Here s the ones on my 05.
Plan to change to a three gauge and add tranny temp.
Old Dec 5, 2007 | 09:34 AM
JCLeary's Avatar
Here is my setup in my now-sold '03. SPA Rail/Fuel pressure in a SRT-10 pillar, Isspro EV boost/EGT in an Autometer dual pod, and TST PMCR in the ashtray...
Old Dec 5, 2007 | 10:07 AM
rufushusky's Avatar
Wow I really like that! Very Clever man.
Old Dec 5, 2007 | 11:09 AM
enafzige's Avatar
Well, here's my work in progress...
--Eric
