fueling problems
I get a slight stumble upon hard acceleration I feel i maybe getting some air or the air dog 150 can`t give enough fuel its hooked straight to the cp3.what could be the most likely problem first and then to the least in order.
150 has the capabilities of handling the fueling for a lot more than you are laying down. what tuning are you running? any cp3 work? last time you changed filters?
welcome to DTR |
fuel filter has about 8k on it no leaks in the lines cp3 is stock.Smarty tntr,no fuel in the oil.
If it is cold out Good ol Diesle Fuel does not flow so well! I know on my truck if I get into it, the truck will sputter. Once it gets warm out it should be fine.
You have been kinda cool there right? |
| All times are GMT -5. The time now is 07:55 AM. |
