fuel pump question
fuel pump question
Below is my set up. My question is i just bought a walbro 392 pump and was wondering where i should tie it into the line at before or after the filters.?. Right now Iam running 11psi at idle and i was doing alot of reading on this site and others and it says that i should double my pressure..? not sure if this is correct but it would be nice to see 20psi + on my gauge at WOT!!!
thanks for any input!
VJ
VJ
You are lucky because you do not have to drop the fuel tank on a 2004.5 if it has the orginal pump on the canister. You will need a bypass valve. I use an adjustable swagelok valve but vulcan has a non adjustable set at 20 psi. I also used a pump adapter which replaced the stock pump.
retirednak
03-30-2010 11:00 PM
3500_CTD
14
02-05-2008 08:33 AM
ScreaminEagle
10-31-2007 03:31 PM
Commatoze
19
08-08-2004 09:57 PM
