fuel pressure...up hill surge help
Old Jan 29, 2007 | 08:00 AM
35" 05''s Avatar
Question fuel pressure...up hill surge help
Ive got a thread on another page but nobody is answering so Im gonna give this one a shot. While going uphill on the interstate at the same speed of about 70-80mph I have always felt a little surging or what feels like gulping for fuel. Yesterday I watched my gauges. Doing 75mph it starts surging "not on cruise ctrl" at the top of the hill but I realized it doesnt do it until fuel pressure hits 5lbs. Then If I were to hit the gas I dont think it would go any faster if I wanted it to. But I dont seem to have this problem at WOT? I need to know if the fuel pressure is the problem to know whether or not to order the lift pump. Thanks for any help.
Old Jan 29, 2007 | 08:20 AM
MikeyB's Avatar
What's the boost doing?
Sounds like 5psi is plenty, if it's 2 or below it could be a problem.
Have you tried removing the boxes to see if the issue is still present?
BTW, it's not uncommon to have some light surging with performance boxes, my EZ does it.
MikeyB
Old Jan 29, 2007 | 08:24 AM
35" 05''s Avatar
MikeyB
my boost is at 10psi. i didnt take the boxes off b/c its just a pain for the bddl. I have had surging with the quad once before but this is only up hill when it hits 5lbs. I have to slow down and let the fuel pressure get back up.
Old Jan 29, 2007 | 03:28 PM
35" 05''s Avatar
bump...........
Old Jan 29, 2007 | 07:31 PM
skynyrd's Avatar
i would suggest a fuel pump i just install my gdp-392 and i set my fuel pressure up to 30 psi at idel and at wot it only drops to 18psi and it just runs
Old Nov 11, 2007 | 07:10 AM
Tree DR's Avatar
I seem to have the same issue that you discribed it only seems to do it around 2200-2800rpm with high boost levels. What did you finally find as the problem.
Old Nov 11, 2007 | 11:04 AM
35" 05''s Avatar
it was my quad xzt that tapped into my throttle position sensor
Old Jan 1, 2008 | 08:39 AM
Tree DR's Avatar
Throtle position sensor?
Does a edge EZ tap into the throtle position sensor? The previous owner claimed that is all he ever put on my truck but it dynoed without the edge at 342hp so something was on it still. Since then I had the ecm flashed and the power surge is still there.
Where is the tps located? I also have a scan gauge and watch the tps and it doesn't bounce up and down when it surges. I've never had a code set either.
Would the jake brake be taped into the tps?
Old Jan 15, 2008 | 07:28 AM
Tree DR's Avatar
Bump No one else has any ideas.
Old Jan 20, 2008 | 06:24 PM
06RAM2500's Avatar
You need a fuel pump. I have a fass 95 gpm, and works good.
Old Jan 20, 2008 | 07:31 PM
Spooler's Avatar
I have a quad box and I don't have that issue. Check your Quad wiring harness for wires that have the insulation come off/seperated. Mine has done this and I just taped the bare wire up. Problem solved. It happened when I was installing my box back on my truck. Noticed it when plugging everything in. Must of pulled it loose when running wires through the firewall.
Ram it Down
Mar 29, 2014 12:46 AM
diablo1
Dec 31, 2010 09:42 AM
Onemoparnut
Dec 23, 2010 08:04 PM
35" 05'
Apr 18, 2008 06:47 AM
BigBully
Jun 19, 2007 10:50 PM
