Fuel leak since Airdog 100 install at filter canister.
Old Jan 30, 2009 | 06:51 PM
Spooler's Avatar
I just wanted to know if there is supposed to be an oring on the banjo bolt going into the adapter plate of of the fuel filter canister. I know there is supposed to be one. Is it supposed to be between the adaptor plate and canister or on the banjo bolt to the adapter plate? That is where my leak is. Airdog has been on the truck for over 2 months and now it is leaking. Dang aggrivating.... I hate redo work.
Old Jan 30, 2009 | 09:42 PM
lmills's Avatar
you ran yours to the factory fuel filter canister? You are supposed to plumb it directly to the cp3
Old Jan 30, 2009 | 09:45 PM
Spooler's Avatar
Yeap, I wanted to keep the fuel heater, the non-working WIF light, and the extra filter. Works fine. except for the darn leak....LOL
The fitting for the CP3 fits on the adaptor plate (retro fit kit part) where my old LP was before I got the intank unit.
Old Jan 30, 2009 | 09:58 PM
Spooler's Avatar
Bueller, Bueller, Bueller......
Old Jan 30, 2009 | 10:01 PM
lmills's Avatar
OK, on the retrofit piece, there should be a small oring that seals it to the back of the fuel filter canister. Then, where the 12mm to -8 fitting is for the air dog system, there should be another rubber oring washer to seal it to the retrofit adapter. Do you have both?
Old Jan 30, 2009 | 10:04 PM
Spooler's Avatar
Yeap, I got both on there. Stupid thing. I do have a spare though... cause I stayed in a Holiday Inn last night.....
Old Jan 30, 2009 | 10:08 PM
lmills's Avatar
LOL, what happened did the wife throw you out. J/K some times you just get a bad seal once in a while.
Old Jan 30, 2009 | 10:10 PM
Spooler's Avatar
Naw dude,,,, Just joking around. Besides I have a nice LQ horse trailer.... That is my dog house.....LOL
It's been fine for 2 months, I will replace it tomorrow...
Old Jan 31, 2009 | 05:54 AM
Hounddog's Avatar
Dang fuel leak is stopping him from picking up a Tobiano Walking Horse gelding he bought from me! May have to use my virtually STOCK truck and take it to him!
Old Jan 31, 2009 | 07:39 AM
rjm022's Avatar
i had the same problem with my fass. the o"ring and the adapter plate would leak at the fuel canister.. replaced o"ring,etc-would always start leaking again. i solved the problem by buying a 2nd gen fuel bowl canister. i fabbed up a mounting plate and installed it. on the back of the 2nd gen fuel bowl canisters-there are threads for a fitting-unlike the 3rd gen's. solved my problem. new canister cost me 80.00 bucks at cummins,
Old Jan 31, 2009 | 08:03 AM
MikeyB's Avatar
Be very careful installing the adapter into the fuel filter canister. It's very easy to nick the o-ring during installation and can start leaking. Always lube the o-ring with silicone grease before installing.
MikeyB
Old Jan 31, 2009 | 11:58 AM
Spooler's Avatar
Well, I got it squared away. The adaptor was bottoming out because the o-ring/washer was not thick enough. Of coarse I am not putting it where it was designed to go so, Oh well. I just added one o-ring washer from the original bajo bolt assembly. The adaptor now has enough pressure to squish out the o-ring washer. Moding stuff is always a pain some where down the line. I'll see how this holds up.
Old Jan 31, 2009 | 11:59 AM
Spooler's Avatar
See ya next Saturday....
Old Feb 1, 2009 | 02:04 PM
Hounddog's Avatar
Hope weather holds and we see you and your wife then.
Old May 5, 2009 | 03:00 AM
ctd4stan's Avatar
Can anyone please post a pic of this AD adapter? I maybe doing the same setup and someone said they have one, but I don't know what it looks like.
3+ months later, is the o-ring leak "fix" working - no more leaks?
