Fuel Filter Position
Old 07-24-2018, 07:31 PM
john40's Avatar
Can an auxiliary fuel filter (Donaldson P551313 or Cat 1R-0750) be mounted in a horizontal position and still be effective. This may be done to increase ground clearance.
Thanks John
Old 07-25-2018, 09:39 AM
johnh's Avatar
Thanks John
my opinion is filtering occurs when the fuel enters the filter under pressure regardless of position....maybe i'm wrong
Old 07-30-2018, 01:49 AM
400HP's Avatar
If you mount it horizontally you would likely have a problem bleeding all the air from it. Not sure if that would be a problem.
Old 07-30-2018, 08:18 AM
johnh's Avatar
i think most filters have a drain fitting on the "bottom" to drain out any water that may have been introduced in the system!
so it must be mounted vertically
Old 07-30-2018, 01:11 PM
john40's Avatar
The fuel filters I mentioned don't have drain valves, but I appreciate your replies.
John
Old 09-06-2018, 12:58 PM
cromulius's Avatar
Im sorry to say i dont have the answer because I would like to know also. I definitely have never seen any diesel fuel filters mounted horizontally. I just picked up a 3rd gen and want to add a 2 micron cat and the fass stock replacement pump. I dont like frame mounted filters hanging down because I am often off road for work. There is not much room under the hood either.
Old 09-07-2018, 08:17 AM
cromulius's Avatar
https://puredieselpower.com/dodge-pr...pps-mount.html
This looks like a good mounting option.
maxx250
08-23-2007 08:32 PM
bob95065
21
08-21-2007 05:16 PM
Chrisreyn
02-11-2006 12:42 PM
sammy340
01-18-2005 06:10 PM
halerazor
05-04-2004 09:55 AM
Quick Reply: Fuel Filter Position
