-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   Freeze plug fix (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/freeze-plug-fix-156468/)
jlibert Jun 21, 2007 02:47 AM
Freeze plug fix
I am not a mechanic or an english language expert, so follow along at your own risk. I'm not a machnist and I had to get this done tonight so you may take more time to make your parts look pretty. All holes measured on center, measurements are a very close approximation, but should work fine for all intensive purposes. I was working out of my nova which usually stays in my garage and it was 102* yesterday! http://i139.photobucket.com/albums/q...t/CIMG0183.jpg
The freeze plug on my truck blew out and I decided to fix it myself. With the help of others including Dodgezilla04 and PourinDiesel as well as some great information I picked up on the DTR and TDR, I decided to put together a post with pictures in the hopes of helping someone tackle this job in the future. Many have used either the "remove the transmission" technique or the "lay on the valve cover" technique. Dropping the trans seemed like too much work, and I couldn't reach around the back of the block with much success, so I decided to remove the exhaust system for access. Here are the tools I used.
small slide hammer/dent puller from napa (if the plug is still stuck in the block)
http://i139.photobucket.com/albums/q...t/CIMG0179.jpg
8" punch
ball peen hammer
11mm deep socket + rachet
1/8" drill bit with cordless drill
17/32" drill bit
sheet metal screws (came with dent puller)
telescoping mirror
2 1/4" hole saw
3/4" ratchet wrench
(other tools will be necessary and will vary with added exhaust components)
Other supplies used:
new freeze plug from dealer
gasgacinch or equivalent
http://i139.photobucket.com/albums/q...t/CIMG0181.jpg
red loctite
(3) M12 1.75 35mm or 30mm bolts (30mm for 1/4" material, 35mm for 1/2")
(3) lock washers
Mopar antifreeze (red/orange)
brakecleen or equivalent
In order to access this particular plug, I removed the exhaust elbow (pacbrake in my case) and downpipe. This gave access pictured here
http://i139.photobucket.com/albums/q...t/CIMG0174.jpg
Auto trans guys have a cooling line that runs behind the block. Auto guys should probably use 1/4" steel instead of the thicker aluminum to provide more clearance.
http://i139.photobucket.com/albums/q...t/CIMG0173.jpg
Steps to remove stuck plug
1. Try to knock plug sideways with a hammer and punch. Grip the side of the plug with a pair of pliars (probably needle nose) and pull plug out
2. If step one doesn't work, drill a 1/8 hole in the plug (anywhere you can). Using the dent puller kit from Napa, screw the sheetmetal screw into the plug and extract with slide hammer.
Careful not to penetrate the engine block as it sits very close to the back of the plug
3. Once the plug has been removed, clean the hole with brake parts cleaner or equivalent.
Building a plate to prevent the plug from coming out again. This plate is also used as an installation tool in this application. Use 1/2" thick aluminum plate or similar strength steel plate. A template similar to the one shown below will need to be made.
http://i139.photobucket.com/albums/q...t/CIMG0166.jpg
Holes were drilled with a 17/32 bit. (9/16 should also work fine) and were spaced as follows:
top to top measured across = 7 11/16"
top to bottom measured down = 2 3/8"
top to bottom measured diaganolly = 7 7/8
bottom hole is slightly offset from hole above (see pic)
holes may be slotted horizontally to ease installation.
After the template has been applied to the material, machine accordingly.
Use the hole saw mentioned above to produce a circular piece of metal 1/4" thick that will me screwed to the piece pictured above.
I used a larger bit to counter sink the self tapping sheetmetal screw. The circular piece will need to be machined to fit inside the new plug. Leave some clearance between the plug and the circular piece as the plug will compress slightly when driven into the block. It should look something like this
http://i139.photobucket.com/albums/q...t/CIMG0168.jpg
http://i139.photobucket.com/albums/q...t/CIMG0169.jpg
Make sure you have adequate clearance between plate and bellhousing. If there isn't enough clearance, the plate will hang up and drive plug in crooked.
Installation of the freeze plug
Using some gasgacinch, adhere the new plug to the circular piece of the metal plate. Move the plate into position, and using the bolts listed above, thread them by hand into the block until they are snug. Using a 3/4" or 19mm ratchet wrench, alternately tighten bolts until plate is flush with block. If you used 1/4" material for the circluar piece, the plug will be driven in slightly passed flush for a factory appearance. You may want to back off plate to verify that plug is installed correctly. With lockwashers slid onto bolts, add a drop of red loctite to each like this
http://i139.photobucket.com/albums/q...t/CIMG0180.jpg
Thread the bolts through the plate and back into the block until tight.
The final product will look like this
http://i139.photobucket.com/albums/q...t/CIMG0188.jpg
replace your exhaust system
re-fill and purge cooling system
check for leaks with engine running
doug60 Jun 21, 2007 04:26 AM
Nice , thanks for taking the time .
abc4yew Jun 21, 2007 06:13 AM
Great write up!!! This should be a sticky! Extra points for the Gasgacinch girl!!! ks
trik396 Jun 21, 2007 06:48 AM
That Gasgacinch looks like it's from the 50's... very cool. And great write-up. I did mine from over the valvecover and under the truck but if I had lost the plug like you, I would have gone your route. My way, I couldn't see the plug at all. And I highly agree with you that auto guys should use 1/4" plate and nothing thicker.
Nice looking Nova also.... You California guys with your great weather...[duhhh] I haven't seen a Nova around here in decades...[laugh]
Luvnacumns Jun 21, 2007 08:11 AM
Wow thumbs up!!!! Awesome write up.. I have the template somewhere and was waiting for warmer weather to do this mod!!!
Thanks Again!![guitar]
trik396 Jun 21, 2007 08:20 AM
Also, if you look at where the trans meets the back of the block, you can see how it's rounded. I had to cut that shape into the plate. At first it was flat, but wouldn't drop down enough to fit... fyi...
CamperAndy Jun 21, 2007 08:46 AM
Nice write up and I like the toolbox setup.
Can you tell us any of the details on the blow out? How hard were you getting on it and do you think you were fully up to temp??
53 willys Jun 21, 2007 09:12 AM
Nice write up dude[guitar]
I think the plate looks great:cool:
jlibert Jun 21, 2007 09:17 AM
I have always been fully aware of the potential for the freeze plug blowing out. Becuase of this, I always let my truck reach full operating temperature before any heavy acceleration. In this case I believe the truck was at operating temperature, but I don't believe the thermostat had fully opened yet[duhhh], WFO, Boost at 50 = blown freeze plug . I wish I would have put the plate on before all of this happened. In my opinion, this is a must do mod. Imagine being hundreds of miles away from home without all of the tools needed to complete the installation. The dealer wanted $1000 for this, as they said the transmission needed to be removed. They wouldn't install the plate either!
53 willys Jun 21, 2007 09:23 AM
I still think the best fix(along with the plate) would be a heater control valve plumbed into the top hose...open the valve for racing and you have bypass flow no matter what the T-stat is doing:cool:
dodgezilla04 Jun 21, 2007 09:30 AM
great write up, glad it worked out for you.
i was in the same situation when mine blew.
mark(53 willys) hold out another few weeks on that heater control valve. there is something to deal with this available very soon. the manufacter is almost done and then he and i will install and test. and i am gonna try to pop a plug to see if it completely cures it. :)
XLR8R Jun 21, 2007 10:10 AM
Great exposition jlibert! :cool:
It's now a sticky on my desktop...
Looks so good, I'm going to machine a fancy aluminum one with SS hardware just so people ask what the heck it is. [laugh]
I've got all 3 dozen or so parts for this BOE kit spread across my desk right now - looks pretty cool, all stainless steel & brass & aluminum... can't wait to install it on the '05 Saturday! [roll]
[director] Photos & test results Monday. [coffee]
cquestad Jun 21, 2007 10:26 AM
That plate looks similar...hehe.
Might as well put liuid gasket around the machined flat surface of the plug hole too...as a second seal. I did on mine.
That is a great pattern...mine fit like a glove.
53 willys Jun 21, 2007 10:33 AM
I'm not making anything at the moment...I got way too many other projects[duhhh]....
is this XLR8R's kit you speak of???
dodgezilla04 Jun 21, 2007 10:44 AM
yes it is. been waiting but now it seems mikes about ready to ship. whooo hoooo. wanted it by next week so i could have it installed for my 2k mile camping trip 4th of july week, but it can wait. :)
