FP gauge
Old Mar 6, 2008 | 04:22 PM
dieselkid6's Avatar
Exclamation FP gauge
i just hooked it up and it goes to seven psi and stays there? What is going on with it
Old Mar 6, 2008 | 10:04 PM
JCLeary's Avatar
What kind of fuel pressure gauge?
How did you hook it up?
Old Mar 6, 2008 | 11:24 PM
Fisherguy's Avatar
I'm not sure what you're getting at, 7 - 8 pounds is about all you're going to get out of the factory lift pump.
If you're saying it doesn't go down when you punch it it's probly the isolator screwing up if you used one...
Old Mar 7, 2008 | 08:35 AM
donnee's Avatar
I just had one installed as well.
Im using a banjo bolt to feed the isolator.
Since the install, the gauge has showed a rock steady 7#
Old Mar 7, 2008 | 02:16 PM
dieselkid6's Avatar
same setup, on crazy larry it does move when its on the floor but icp drops to 11600 so i know shes starvin
Old Mar 8, 2008 | 10:18 AM
donnee's Avatar
Mines on a bone stock 05.
Also had a chance, since the install, to try the gauges on the freeway.
The Tranny sat @ 170 on the freeway and the Fp did drop to 5 # on heavy throttle but bounced back once I got to 70.
mtl0727
Oct 12, 2005 01:02 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
