Floor-IT's "BETTER" Bag of Parts/Arson Slayer PICS!
Well fellas I had the chance yesterday morning to get John's kit installed on my truck and got some pics of the parts next to the stock ones, pics arnt the best but they give ya an idea. I must say that you would have to see these parts in person.... WOW is all I can say, John sure worked his magic on em thats for sure!
I took my time on the install and everything went great, took about 45mins.
Once I was finished I fired the truck up and made sure there was no leaks anywhere and could instantly tell that there was more RP even at idle so I jumped in and the went for a ride, EDIT
Man did my bottom end and mid range pic up BIG TIME!!!! Rail pressure dose not drop one bit and will rocket right to 25k when asked to, I only had about an hour and a 1/2 to play around with it but man my truck feels like a ROCKET SHIP now.
So here is some Floor-IT eye candy!!!!!!!!! (sorry fellas pics could be better)
Man did my bottom end and mid range pic up BIG TIME!!!! Rail pressure dose not drop one bit and will rocket right to 25k when asked to, I only had about an hour and a 1/2 to play around with it but man my truck feels like a ROCKET SHIP now. So here is some Floor-IT eye candy!!!!!!!!! (sorry fellas pics could be better)
second set of pics, the ***** inside the check valve, the old and the new both look like they have rust, and the back of the new gear rotor pump surface looks like it had a few smears or rust....... but as long as its kick in the pants when ya drive, i guess its all good. you should try to make fall brawl, by then you'll be 700 + on fuel only.
In the two pis of the cascade valves, the top pics has the stock on the right and the bottom pic the stock is on the left.. modded one has the brass fitting on the end.
I dont know about 700, but id say im gonna be knocking hard on 650!!
Mike you gonna make Lloyds open house on the 13th?
As for your injectors they will be fine, this kit dosent increase RP untill you use some sort of pressure box to increase rail pressure.
I have the Dipricol Opix gauge, and rail pressure when cruising is right around 15-16k, I was at a sled pull last night and when on the high way running 70 mph it was was up around 18.5 to 19k. But I havent had a whole lot of time with the kit either so....
man dose this modding game ever stop.....
