Flashpaq Fuel Pressure Readings
Fuel pressure readings on a stock '06 with the Superchips Flashpaq:
Stock Idle 5.8k 1500RPM 8.2k 2000RPM 13k 2500RPM 16k 3000RPM 20k WOT RUN 23k Tow Idle 6.4k 1500RPM 8.6k 2000RPM 14k 2500RPM 17k 3000RPM 21k WOT RUN 23k Performance Idle 6.4k 1500RPM 8.6k 2000RPM 15k 2500RPM 17k 3000RPM 21k WOT RUN 23k All readings were taken with zero load in the driveway except for the WOT runs. As you can see the Flashpaq in its current state adds very little fuel pressure. |
Thanks for the info those numbers look real good. Seems that flashpaq is pretty safe and creates good power.
How do those numbers compare to the BD tripple dog? Do they make a flashpack for 2004 305/555?
Surfram, Not yet. they are in the works on it and it should be ready next month. they are testing everything right now.
Nice info.
