first timer looking for some help
Old Nov 27, 2007 | 09:18 AM
rburm's Avatar
first timer looking for some help more pics added
first time poster, long time lurker, time to step up
MPI Maximized Performance Inc.
anybody heard anything on these guys?
Good, bad, indifferent?
looking at their compound turbos for my new 07 5.9L Megacab
just had it stretched to a long box, 22.5" alcoas, complete custom audio/video system going in now and looking to get the engine and tranny done. any help would be appreciated. Hope the picture attachment works
Last edited by rburm; Nov 28, 2007 at 08:27 AM. Reason: encourage traffic to look at thread
Old Nov 27, 2007 | 09:37 AM
crownsey54's Avatar
i have heard nothing but good thing about nathens turbos. lot of people have them and i plan on gettin them when its time.
Old Nov 27, 2007 | 09:38 AM
dodgezilla04's Avatar
i have a set of his towing twins, they are awesome, incredible spool, build boost quickly to 58#'s, has great top end power, the fit and finish are great.
Old Nov 27, 2007 | 11:06 AM
rip 112's Avatar
Now that is a SWEET truck man, very clean-cut. Nathans compounds are the ones to have.
Old Nov 27, 2007 | 11:17 AM
53 willys's Avatar
MPI twins are the bomb!!!! just like your truck!!!
nicely done....your truck looks awesome!!!!!
Old Nov 27, 2007 | 08:32 PM
rburm's Avatar
thanks guys appreciate the compliments.
i've been Ford guy for a long time, but after 3 new motors in 6 months, one in the 1999 7.3 one in the 2008 6.4l and one in the 2000 6.8L V10, i knew it was time to switch camps. I also have a 2003 6.0L the only Ford with the original motor.
what can i expect for HP and torque with the towing setup with mach 3 injectors and a smarty programmerand a 4 inch exhaust right from the turbo.
Old Nov 28, 2007 | 08:24 AM
rburm's Avatar
pics added to encourage response
looking for more feedback on the maximized performance towing twins as compared to the Piers diesel twins.
customer support? service?
i want a reliable plug and play setup
Attached Thumbnails first timer looking for some help-russmegacab-084.jpg   first timer looking for some help-russmegacab-093.jpg
Old Nov 28, 2007 | 09:42 AM
soulezoo's Avatar
DTR 1st Sergeant
A lot of guys here have put on MPI twins and I have not heard a single complaint. There is a lot of praise for his work. I have a set of Piers towing twins and they work great. They are "old school" twins and very reliable, even with smarty on sw7 and banks all the way up towing 10k up steep mountain grades (high elevation) and hot (104*) outside temps, I never got over 1350* egts and usually not more than 1200*; I saw average of 950* on the flats (reminder this is still high elevation and hot outside temps; lower elevation and cooler outside temps would bring overall egts down quite a bit). The thing I always feel compelled to point out though is while Piers designed those twins a long time ago, he is no longer associated with PDR. He has a new place called Peak Diesel Performance. He is also designing new towing twins. He's a smart guy and super nice to work with and absolutely worth your time to talk to him about what you want. That said, there are also other choices in twins whose performance is proven and well known such as BD and ATS and some others. Twins are such a big expense and are personal to the application. I always invite people considering them to do a lot of research before deciding on a particular set.
Old Nov 28, 2007 | 09:55 AM
JCLeary's Avatar
Everyone seems to like the MPI twins. I, however, question the setups that use the stock turbo as the top turbo without an additional wastegate. 600hp worth of exhaust is an extreme amount of CFM to push through a 9cm exhaust housing. While it spools great, I think the drive pressures would be more than excessive. An external gate would solve that problem.
If you're looking at Piers twins, you might as well talk to Piers himself. Piers is no longer associated with PDR. Check out Peak Diesel Performance:
http://www.peakdieselperformance.com...ge/4863099.htm
The nicest twin setup I have ever seen is built by J and H Performance in Redding, CA. They use a top turbo with a 6-bolt flance instead of a 3rd-gen large flange. What that means to you is that there is only 1 clamp in the entire twin turbo setup. No clamps, hoses, or boots to blow off. Additionally they use stainless cold pipes, which look super sweet. The entire setup goes into the truck in one piece. Really sweet. That's what is going in my truck!
http://jandhperformance.com/
Your truck is a beauty and worthy of an exceptional set of twins. Give Mark a call at J and H. I think you'll be impressed. They just did a set on an '06 or '07. With their twins, some 90hp sticks and a Smarty the truck ran over 600hp on a tough dyno without any tuning.
Old Nov 28, 2007 | 10:06 AM
RyeThomas's Avatar
Winner winner chicken dinner!
Ive had 2 sets of twins. An off the shelf 1 size fits all, and a custom set of MPI's. The best thing is Nathan wants a full list of mods, what your overall goals are, and what you do with your truck. He then will get you a few options and prices. You pick the set up that fits you and away you go. MPIs twins are proven in many high hp trucks, both Cummins and D-max. My vote would be call Nathan or pm him, he knows his stuff.
Old Feb 8, 2008 | 04:35 PM
bondkx01's Avatar
was your truck a SRW to begin with? I've never seen that color in a mega cab DRW.
thanks
06RAMCTD
Nov 6, 2009 11:35 AM
CTDPower11
Jan 23, 2007 09:29 AM
TripleBquad
13
Nov 20, 2006 02:59 PM
dsrvingdodge
Mar 18, 2006 05:44 PM
Tarqal
22
Aug 26, 2005 05:40 PM
