First time on the dyno
Well they had a dyno this weekend at the off road expo in pomona. I only ran 380 hp and 808tq. I have a bully dog power pup on extream and a adj ts ramifier on full. 4" exhaust and afe intake with torque tube. I also have the ez boost elbow on. Numbers seem a little low but I might be wrong. What does everyone else think. I'm thinking of upgrading to either a smarty beta or a torque dog with crazy larry.
Kory |
That sounds about right. You need a better turbo on that 03.....
I think that "Spark Plug Conversion Kit" may be hurting you too. The plug tips are probably carbon fouled causing you to lose power...... |
What if I switched to the platinum plugs.
Is your truck a SO?
My truck in my sig landed just about the same as yours did. I did not have a exhaust or a boost elbow though. The numbers in my sig were neted using the BDTD on Performance setting and a Stage ll Dr.Performance box. I have a 235hp SO btw. If you do get the Bully Dog system you will not be able to run the Crazy Larry software for our 2003 trucks. I think it's for the 04's and up. |
I think they will still get carbon fouled unless you get the "Splitfire" plugs..[laugh]
Bullydog didn't work the greatest on 03-04 trucks. You should get a little more power out of a Smarty though.
Yes my truck is an SO. I would love a smarty. I wish there was someone around me that had one I could try before I buy it. I there is someone around me and would like to let me try one please let me know.
Kory |
also depends on the dyno. mustang or dynojet, load or inertia?
This was a dyno on a trailer and they were from south dakota.
That sound's right on for you mods.
That's about the most you're gonna get with the mods you have. Even with a Smarty/mp8 and a II Silverbullet I still only dynoed at 430hp. It's 03-04 syndrome. You gotta spend more to get more. |
i dyno'd 412 with a banks six gun/smarty stack. stock slipping trans, stock turbo, amsoil cone filter with K&N tube, stock exhaust
also, be sure your air conditioner is off. |
I was there too.Didn't dyno but I did watch a CTD dually put down over 1100lbftof torque.It took the lead from a duramax at the time. Come out to Glamis with us,I am sure we can round up a Smarty to try.Oct 26-28
Bob |
Humm might have to make it out there. Might even bring the paddles for my truck
Originally Posted by SlowSixSpeed
(Post 1733114)
That's about the most you're gonna get with the mods you have. Even with a Smarty/mp8 and a II Silverbullet I still only dynoed at 430hp. It's 03-04 syndrome. You gotta spend more to get more. The Bully Dog does suck on a '03-'04. Although I did make good numbers with a Triple Dog/TST stack and a 66-size turbo. 525-555 depending on what number you want to believe. |
