First things to do
Old Aug 13, 2007 | 06:49 PM
dreamboater's Avatar
First things to do
I just bought a stock 06 Ram CTD 4x4, QC, 3.73 48RE. Its hard for me to leave anything alone so of course comes these questions. I am trying to figure out how much of a difference you would see between the two scenarios. Consider buying a drop in air filter (K&N, Amsoil, etc) and then just changing out the muffler to an aftermarket vs buying a cold air intake and complete exhaust system. I figure its a difference of almost $500, would I see that much more improvement with the complete systems? Thanks
Old Aug 13, 2007 | 09:19 PM
trx's Avatar
trx
I think if you were to install a afe stage 2 and filter you would not be sorry. Hard to say how much power you gain but the sound and size of the new intake tube is much greater. If your looking to save money many people make there own aka the *****'s whistler check for that thread also just changing the muffler is a great idea most using nelson or donaldson as the stock exhaust is already 4" not much need to change tailpipe i learned that one little late but my mbrp looks great anyways
Old Aug 13, 2007 | 09:23 PM
hump's Avatar
dreamboater
Intake: A drop in filter will do the trick but a cold air intake will flow more air & help lower your exhaust temps. Plus give you a better sound (turbo whistle).
Exhaust: Just change out the stock muffler for an aftermarket one with better flow, remove stock muffler totally & run just the kitty........Or loose both & straight pipe it....
Old Aug 14, 2007 | 06:50 AM
I have seen some mufflers by MBRP and Silverline, any differences? Or, will they all provide the same results? I think I will spend the extra 150 for the intake, seems like a reasonable expense.
Old Aug 14, 2007 | 06:58 AM
what dimensions are our mufflers. I know its 4" in and 4" out, but what overall length should I look for? What outer diameter should I stay with?
Old Aug 14, 2007 | 06:59 AM
Morse's Avatar
NAPA also sells a Walker diesel muffler.. Model number is 21471. 4'' straight through. Gives a good sound without drone.. I've used them on my 05 and 06..
Old Aug 14, 2007 | 09:13 AM
rustyshakelford's Avatar
look up the whistler intake but 53willys, replace the muffler with a 4" piece of pipe and your good to go!
brett
Old Aug 14, 2007 | 09:18 AM
Would I have emissions issues with out the muffler?
Old Aug 14, 2007 | 09:32 AM
donnee's Avatar
Personally, Im using Amsoil dropin filter and MBRP replacement and I noticed that the EGT s were about 50* lower after the installs.
Muffler is not much louder than stock in the cab on the road.
I dont think you would have emmission problems with a muffler change.
Without the cat you could.
Old Aug 14, 2007 | 08:26 PM
LFD2037's Avatar
rustyshackelford, Have you checked your sig lately? I think the guys @ the station got on your computer while you were out on a call. HAHAHAHAHA!!! Gotta love the fire station pranks! HAHAHA!!! That's funny right there, I don't care who you are.
Old Aug 14, 2007 | 08:28 PM
the muffler being removed will have no effect on emmissions...its strictly for sound. do not remove he cat
LFD2037
you dont support the WNBA?
brett
drewallen42
24
Mar 31, 2007 07:59 AM
swmnkdinthervr
17
Dec 5, 2005 05:50 AM
AlpineRAM
Mar 23, 2003 01:46 AM
TEDHRS
Nov 3, 2002 07:14 PM
DarrellB
Oct 9, 2002 09:25 AM
