Which firewall plug?
I'm in the process of installing a Quad Standard adjustable performance module and need to go thru one of the firewall plugs. I have a 2004.5 CTD Quad Cab dually.
There appear to be 4 existing plugs. On the left is the steering column plug. On the far right a lot of wires plus a large bundle of wires go thru a plug. In between and high is a single plastic wire shroud in a plug. Then in between lower is a solid cable thru a plug. The plug on the far right appears large and best but is hard to see inside the cab. Which plug have you used? Thanks |
I used the plug where the emergency brake cable runs through. I put a slit in the crease of the plug and have run all wires (Commander, Xzillaraider, and offroad lights) through at that point.
i used the grommet where the main harness is, just move the control module below the ebrake, and make a small careful slit.
Originally Posted by ptgarcia
(Post 1257492)
there is even a little bit of a nipple like protrusion(behave fellas, i am serious) that you can run a zip tie around to keep it sealed.
Originally Posted by dodgezilla04
(Post 1257508)
Thanks |
firewall, drivers side, behind the ebrake foot pedal. there is a module mounted vertically. gently move the module aside, there is a clip to the inboard side, and viola! your grommet awaits.
(Post 1257501)
Followed your advice and the grommet with the main electrical harness worked great. Thanks again! |
you are quite welcome,
welcome to DTR. we are here to help you spend your money.[laugh] |
| All times are GMT -5. The time now is 07:55 AM. |
