FASS and modified CP3...ATTN: Diesel-Dan
Quick question i notice on DPP's website they offer pumps for people with modified cp3's. I am running a stage 2 pump, so am i in need of an upgraded FASS? Diesel-Dan what is your opinion on this?
Honestly......
Both of these will work:
http://www.dieselpp.com/billcook/FAS...l%20Manual.pdf
The top one will be less noisy...but they are both are more manageable after the noise updates.
You are good to about 25 PSI on that pump. If you go any higher...motor amperage gets a bit much. These kits were not built for high pressure...wasn't needed back then. BUT i have talked to Jon at Floor It and he said that you can comfortably run your Stage II pump in the 20's and will be just fine. Any gains from any higher head pressure would be very minimal if not any....
im interested in the noise upgrade, but dont want the down time.....my 2nd vehicle currently has no motor....haha Who do i contact for the spring?
WELL...you can get a spring like Blue said. PS-1020 will get you about 21 PSI or so.
OR you can get a ball valve and install it on your return back to the tank. Then crank it down until you get to the pressure you want. Just make sure you dont cut off return flow back to the tank.
