fass install pump stuttering
New fass titanium 150 just installed with draw straw. Pump will make 19 psi then seams like it turns on and off with the pressure going up and down 1 psi approximately. Ran the supply and return into 5 gallon jerry can. Same issue. The only way i can get the pump to run smoothly is to run the ip supply line into a can. Fass tech support website says to contact them at this point but I have been trying for two days to get through to them with multiple emails and voicemails. I need this truck running now hopefully someone here has had the same issue.
bigd450
11-27-2016 10:09 AM
06dmc
09-15-2006 07:32 PM
Warlord
06-15-2006 07:21 PM
