Factory Toggle Switches
Old Aug 5, 2005 | 02:45 PM
walt_mink's Avatar
I have an 05 with the Laramie package. In between the two heated seat switches are two blanks which are just begging to have accessories installed on them. Does anyone know of a switch that matches the heated seat toggle? I thought of just buying a couple of heated seat switches from the dealer as well ... anyone have experience with that?
Thanks much!
Old Aug 5, 2005 | 03:26 PM
MedicShawn's Avatar
I believe someone bought a couple of heated seat switches and used something like goof off to get rid of the writing on the switch.
Old Aug 5, 2005 | 07:59 PM
Jeff in TD's Avatar
The factory seat heater switches are resister multiplexed momentary type, so using them to power anything else would be difficult.
The resistance between pins 4 and 6 will be 2.2 k ohms in neutral, .415 k ohms in low, and 33 ohms in high.
The control module that turns the heating elements on and off will go into error mode if it doesn't get a reading from the heat sensor that is within range, and it will also go into error mode if the impedence of the heating element is out of range, so trying to adapt the heated seat control module to operate something else isn't going to work, either.
If you find a source for matching switches, though, please share. I think a lot of us would be interested.
Old Aug 8, 2005 | 09:38 AM
walt_mink's Avatar
That's great information Jeff. I'll get looking into it and will share what I find out.
Walt_Mink
Old Aug 8, 2005 | 08:55 PM
MedicShawn's Avatar
I looked at the powerwagon today and they use a switch for something. Maybe the electronic swaybar disconnect? Maybe it will suit your needs.
Old Aug 9, 2005 | 06:29 PM
DR3500's Avatar
the lockers would be my guess.
Old Aug 9, 2005 | 10:19 PM
mestdagh's Avatar
The powerwagon must have 3 extra switches. 2 lockers and the swaybar.
Old Aug 10, 2005 | 09:14 PM
DR3500's Avatar
I don't think it has 3, there are only 4 holes and the heated seats take up two. one of the switches is probably a 3 pos switch 1=off, 2=rear locker, 3=both lockers. That is my guess because I haven't seen a powerwagon yet.
Old Aug 11, 2005 | 09:04 PM
db's Avatar
db
I read that it was a sway bar disconnect. I also think that there is a rear power slide window option on the 06 ers that use the 4th spot.
dj
Old Aug 13, 2005 | 01:07 AM
DR3500's Avatar
the powerwagon has the electric lockers in both axles.
CODODGE2500MAN
Sep 17, 2009 08:42 AM
vnapple
May 27, 2008 10:45 PM
j2mk
14
Nov 1, 2007 01:36 PM
RockcrawlingTJ
23
Jul 16, 2006 10:03 AM
sr148
Dec 6, 2005 09:20 PM
