F1 Springs/Stock cam
Old Feb 13, 2008 | 03:16 PM
Dieselhed's Avatar
F1 says there Pro/Sportsman valve springs were designed for the Helix 2 and 3 cams. Can they be used with the stock cam? I would like stiffer springs for higher rpm fueling. If not, what spring options are there. Is it even worth it or are the stockers o.k. for the occasional high rpm run?
Old Feb 13, 2008 | 03:58 PM
cgmorgan06's Avatar
I think I read somewhere that the stock springs are good to around 3500 rpm.
Old Feb 13, 2008 | 04:09 PM
jwb600's Avatar
i think theres a couple guys running that setup on here
Old Feb 13, 2008 | 04:21 PM
Timinva's Avatar
DTR Advertiser
The F1 springs are fine with a stock cam. Tim
Old Feb 13, 2008 | 05:36 PM
Dieselhed's Avatar
Thanks. I think I'm gonna stick with the stock springs for now. And try not to get carried away with the high rpms......
Old Feb 13, 2008 | 05:56 PM
omaharam's Avatar
Umm. A little birdie told me that they are too stiff and that it will wear the cam.
Old Feb 14, 2008 | 02:18 AM
tristan21's Avatar
I heard a similar chirp on comp d a while back
Old Feb 14, 2008 | 05:41 AM
CTD03's Avatar
would 6.7l springs work in the 5.9
Old Feb 14, 2008 | 07:01 AM
Bad-Duvall's Avatar
Befor you think that its ok to run high rpms with stock springs look at what happend to my motor. this was where between 3500-3700 rpms.
http://www.competitiondiesel.com/for...ad.php?t=22839
Oh yea my motor only has 9000mi on it.
Benn Duvall
Old Feb 14, 2008 | 07:06 AM
Timinva's Avatar
DTR Advertiser
We have had no issues with F1 Springs on a stock cam. Several trucks running that way over a year. Tim
Old Feb 14, 2008 | 10:40 AM
RamNu2's Avatar
THe rpm's is not the only thing hindering the stock springs so to say. Also look at what boost numbers/airflow you have. It is also possible that the stock springs could be getting forced open a little and letting air go by. Thats one more thing to think about.
Old Feb 14, 2008 | 10:43 AM
Sloverado's Avatar
I to am running heavier springs with stock cam. Not been in there long enough to tell.
Old Feb 14, 2008 | 12:04 PM
tristan21's Avatar
Good luck to you slow. Im sure if the professionals are sayin it will hold up im sure you'll be ok. DonM is on today maybe he will respond as to how good that cam will last.
Old Feb 14, 2008 | 12:10 PM
Dieselhed's Avatar
Benn Duvall
I don't push my motor anywhere near 3,500 rpms. It would just be a precautionary measure. I'll be in there doing studs anyways so I am just trying to kill 2 birds with 1 stone.
Old Feb 14, 2008 | 12:14 PM
graphitecumnz's Avatar
we know you want the springs...
