Evil twin leak
Old Jul 30, 2009 | 07:48 PM
dfseidel's Avatar
Evil twin leak
Still having issues with a leak at the top evil twin duramax cp3 from the hardline/nut. Having trouble reaching Lloyd. Anyone have any ideas on finding a replacement hardline since I suspect a flare is damaged.
Old Jul 30, 2009 | 08:04 PM
Bswope's Avatar
Give Lloyd time he will get back with you if you leave him a message! Lloyd will get ya fixed up!!!!
Old Jul 31, 2009 | 07:05 AM
OT-OF-Here's Avatar
I'm guessing
You've already tried thread tape or fitting sealer?
Old Aug 2, 2009 | 01:00 AM
dfseidel's Avatar
I had thought about that but the leak is between the nut and the hardline. I'm not sure how a thread sealer could be put there to contain 26k psi....
Old Aug 2, 2009 | 10:09 AM
Timinva's Avatar
DTR Advertiser
Dont put thread sealer there. I had a slight leak there and pulled the line to ensure it was clean and the threads were good, put it back on and used a crows foot and got it really tight. It took alot more torque to get it to stop than I initally thought to get it to quit leaking. Been a month now no more leaks. Tim
Old Aug 2, 2009 | 06:13 PM
dfseidel's Avatar
Will try - any thoughts on actual torque range? Don't want to break it....
Old Aug 2, 2009 | 06:30 PM
Timinva's Avatar
DTR Advertiser
I used a 19mm crows foot, 6" extension and a long ratchet. I pulled pretty hard, if I had to guess it was probably 45-50 ftlbs or so. Be carefull though dont want to break it. Tim
Old Aug 2, 2009 | 11:54 PM
dfseidel's Avatar
Okay. I'll give that a whirl!
Old Aug 3, 2009 | 01:00 PM
jaredb900rr's Avatar
While tightening the nut try wiggling the hardline at the same time to take pressure off it and torque it tight like tim suggested. If that doesn't work, check the flare for a crack.
Old Aug 3, 2009 | 01:22 PM
WUnderwood's Avatar
good luck getting ahold of Lloyd, I tried for months...
Old Aug 3, 2009 | 03:13 PM
nrussell's Avatar
Yeah tell me about it. I ordered his Evil twin kit on July 7th and still don't have it. He email'd me back on July 21st and said it was basically ready and I have sent him 3 email's since then with NO reply's. Awesome customer service, huh? When and if I receive my Evil kit, I wonder if he will be available for any install or troubleshooting questions? It's sad that I have to post this, but maybe I will hear from him because of it. Where's the love Lloyd?
Old Aug 4, 2009 | 08:22 AM
dfseidel's Avatar
Out of curiosity - what does the flare look like on the hardline? Is it just a tapered flare or does it have one step?
Old Aug 4, 2009 | 06:55 PM
mudder500's Avatar
Take a 19mm and a 5lb hammer and reflare it. Thats what i was told basically. No biggie least urs aint blown apart twice in 8k miles and left message and no call back. First time taken care of. Now 6 days later i just took it off and back to stock
Old Aug 4, 2009 | 07:24 PM
6.6lEater's Avatar
Install high pressure lines to the injection pump to the junction block.
Tighten
Tighten the fittings to 44 N·m (32 lb ft).
Hope that helps, from gm, doesn't sound like much though.
Make sure the line is clean, we have been having lots of leaks after doing injectors. They want us to clean them all up with a bead blaster, I usally just hit it with a wire brush and no problems
good luck
D2
Old Aug 4, 2009 | 08:07 PM
mudder500's Avatar
U tighten one of these to 32ft pounds and it will shoot fuel like a volcano. I know cause it happend. Thats why i posted bout useing a hammer and reflare it
