Espar D5 Heater - Blower/Fan Motor ?'s
Old Sep 16, 2009 | 11:08 PM
lucey's Avatar
I have an Espar heater installed on my 2500. I would like to know from the guys who run this kit with it hooked to the blower/Fan motor the following:
1. Does it drain the batteries until a certain voltage and then cut out, or does it drain until the batts are dead ?
2. How do you set the system up to operate ? Do you set the blower prior to shutdown and then it blows at the last speed set ?
Overall impressions of having the blower hooked up... Yes i would do it again or no, never again ?
Any other Espar insights ?
Old Sep 17, 2009 | 09:08 PM
lucey's Avatar
Someone must have the skinny on this Espar stuff !
Old Sep 17, 2009 | 09:56 PM
han solo's Avatar
Can only guess. I have a Webasto. There are kinda the same. Most diesel heaters are suppose to turn off @ a preset voltage so there is still enough power to start the engine. As for the heater motor running. I didnt bother installing the harness that runs the in cab heater. Im only concerned about having the engine warm & being to start. With in mins or less have heat blowing from the vents. If you cant find any real answer. You could call Polar heating/ref in edmonton.
Old Sep 28, 2009 | 06:09 PM
Powerken's Avatar
It has a voltage cut off at 10.5 volts, and should still start the engine. The blower runs at the dash set position.
Old Sep 28, 2009 | 11:39 PM
Kevin Barrett's Avatar
I posted several responses to this thread at the Cummins Forum
with some answers to these questions.If you have to learn to not
flatten your battery,it's no big deal.
Search your initial post on the CF and it's there,
Espar totally ...totally rocks.No worrys.
Jim Lane
Apr 5, 2020 06:03 AM
24V83
Mar 3, 2013 10:08 AM
Dodge Demon
Dec 4, 2008 07:41 AM
NoSparkplugs
Jan 22, 2007 05:30 PM
rumblingpeet
Jun 20, 2006 08:38 PM
