Edge Programmer ?
Edge Programmer ?
Anyone here running an Edge Juice Programmer? If so What setting do you use for normal driving, and best fuel milage? I've been on 1 but fuel milage hasn't been that great.
I have an Edge Juice W/A I run on 3 when not towing and 2 when towing. The number 3 setting seems to get the best MPG for me. I generally use those two settings never have used 4 and I don't have the "hot unlock" option don't need it for what I do. I am sure others will chime in on this post.
I,ve had the E/ATT on since new and quite happy with it,tow on 2, 3 running empty.Don,t think there are any fuel savings that i,ve seen,but similar mileage weather its on or off towing.You can play around with the fuel settings for low or high end fueling, makes quite a diff in performance.
I have noticed power gains compared to settings 1 and 2 at 1800 rpms and up. When I was towing my fiver the edge went out back to stock then I really felt the power difference. Sent the edge back in to have it updated and the monitor replaced. No problems since...
Thanks for the responses, I'll run it on 3 for awhile. Wonder if the 4 or 5 setting does anything worth while? I know the book says not to use these settings w/o engine mods
, but sometimes they are over cautious.
morkable
Feb 15, 2007 10:23 AM
SconsinSmoker
Jan 29, 2007 04:27 PM
onebadmudder
Nov 6, 2006 07:25 PM
jlells01
Oct 18, 2004 06:50 PM
thecatsfan
Feb 11, 2004 01:58 PM
