edge juice w/attitude and smarty stack... does it work?
ok this is a little bit of a stupid quetion, but can i stack this with my smarty or are they both programmers. or can i run the edge and then put the smarty on a non timming setting?
Thanks, Eric |
I have heard that you can, and it works, and you can, but it does not do anything...
I'm gonna change the title a little... hope you don't mind... |
I wouldn't mix the two. You see no positive gain from the stack...and sometimes a negative one.
I've read that it isn't a good stack. A better stack is the Smarty and the Edge EZ. The Juice adds timing and duration--- so does the Smarty. The EZ just adds pressure.
It works fine. I don't believe it will gain any higher peak hp over the Smarty by itself, but it does work. You can load a low to medium SW and then use the Juice for some adjustability. In fact, a couple weeks ago, my dad and I were on the same road and I knew he only had Revo sw5 loaded and I had the TNT sw9 loaded, so I started messing with him. All of a sudden he floors it and I'm barely faster. Well, he had turned the Juice up to 5 and his mp8 up as well. That combo on his '06 feels just as strong as the TNT, but at this point we have not had either of our trucks on the dyno to do any real comparisons.
Bottom line, though, is that they do work together. |
omaha has it right, it does work, but there are better stacks, like everybody else mentioned.download revo non tnt, thats better then what you currently have. you can adjust options in the revo also. RP, etc.
