"edge" juice problem's.....
Old Sep 17, 2006 | 06:48 PM
dieselpower04's Avatar
Is anybody having issues with there rig after installing the edge"juice"??
Old Sep 17, 2006 | 07:01 PM
DISTURBED's Avatar
like what? i dont know why but every once in a while my moniter will shut off out of the blue
Old Sep 17, 2006 | 11:56 PM
XLR8R's Avatar
There's been enough problems reported about the Edge boxes that I wouldn't consider putting one on my truck.
Old Sep 18, 2006 | 05:14 PM
scottsjeeprolet's Avatar
Well what's the problem? don't keep it a secret
Old Sep 18, 2006 | 09:26 PM
XLR8R's Avatar
Edge products are a common denominator in posts reporting driveability/fueling system issues.
Old Sep 18, 2006 | 11:20 PM
genesis's Avatar
That sucks..I just put on it mine
Old Sep 18, 2006 | 11:38 PM
XLR8R's Avatar
Chances are you'll be OK... you can save yourself a lot of trouble if you have a fuel pressure gauge!
When did your lift pump and VP44 quit?
Old Sep 19, 2006 | 12:02 AM
QWKRTNU's Avatar
Had mine on for 30000 miles and not a single problem or code
Old Sep 19, 2006 | 01:01 PM
Well for starters my lift pump took a dump then sometimes on start up it's really bogging down and sounds like crap. and I get abunch of codes but nobody seems to know what they are. it's running go right now, but when this all happens again i'll keep a record of the codes and give you all a hollar to figure it out
Old Sep 19, 2006 | 01:11 PM
QWKRTNU's Avatar
My buddies backlight on his screen went out and he called edge. They told him to sent it in for repair and they send him a whole new one. I would just call and tell them what is going on. They seem good about sending new ones out. It may take a few days to get but it might be worth it.
Old Sep 20, 2006 | 11:42 AM
Diesel Dummy's Avatar
The only real problems you will have is not enough fuel pressure, and that will be with any box that taps the pump. Just add a second lift pump and no more problems with fuel pressure. Just double check and recheck all your connections.
Old Sep 20, 2006 | 01:08 PM
XLR8R's Avatar
Originally Posted by Pull U 2
My Edge has been flawless, can't say that about the other box I had.
Well, don't be shy - go ahead and flame the other one (inquiring minds want to know!)
Old Sep 20, 2006 | 06:37 PM
XLR8R's Avatar
That, I will not do. Sorry it's just not my style
Hmmm - so much for the free flow of information back and forth.
If a part failed to function as expected/promised etc. for me, I would consider it my duty to help other's make the same mistake.
No worries, though - there's lots of box problems archived already to form a statistical base.
