edge juice/att bddl stack
hey yall i got the edge j/a and thinking of stacking the bully dog tripple dog with the edge and was going to see if any of yall out there has the same set up and what yall think about it and what upgrades do you have to run it and what seetings yall keep them on without blowing stuff up... any suggestions are welcome. thanks alot!!!
I have it in an '03 a little diff. from yours. Will you be getting the "Crazy Larry" program? You will def. need a performance lift pump replacement or a pusher. If you want your tranny to live, I would at least reccomend a TC&VB. When I have everything turned up, I notice some slight surging during normal driving. The cruise is unusable also. Under throttle though, it is a very smooth power curve. I don't know about the new Triple Dog, they were supposed to solve these problems with the new programs. I still have Ver./1.54 they are on 2.34 now. Some have said they aren't as aggressive as the original Power Pup in the lower rpm's. Have any other q's just ask.
I would not run that stack personally. they are both timing and duration boxes. now I am sure you can stack them as long as you don't run them both on the higher levels but I guaranty you you truck won't like level 5 and extreme at the same time.
I would stack the the MP-8 or the edge ez with the juice. if you want more timing and duration upgrade to the hot juice as they have desiged the amount of timing and duration to be safer.
that being said I error on the safty side not the power side. I would get the mp-8 and then if you still want more upgrade to the hot juice (free with TDR subscription) or get the tst powermax.
I run the bully dog pwer pup stacked with the edge juice and seem to think it works pretty well. I have looked it up and edge does 180 hp hot version with just timing and duration well with the bully dog it is pretty much the same thing on the extreme setting you get 80hp from timing and duration and 50hp from pressure. I seem to like the satck as the bully dog pulls real aggressive down low the edge kicks in half way and then the bully dog takes over again up top. But if you are on stock clutch and fuel system use in moderation. I will be posting after I get back from the dyno tomorrow so I will let you know how well this stack work. Oh yeah and on another note I would not run the crazzy larry version with the juice though I think then you are just asking for trouble.
Kman, what configuration is the '05? 2500/3500 4x4, QC, Reg. cab, dually, or single wheel. Just wondering. My truck dyno'd 371hp/714tq with just the BDPP. The #'s were 267/490 stock. I haven't dyno'd since I stacked chips or built the tranny. But sseing as how I dropped over a second in the 1/4mi. 14.9sec. w/only BDPP and 13.7sec. after tranny mods and J/A. I know I'm close to 450hp and over 800tq to the rear wheels. Just make sure you get stock numbers before turning everything up so you can give us a baseline of improvement.
cr25ovet
Jan 19, 2008 11:12 PM
JIT
Oct 19, 2006 09:55 PM
ocsurf16
Oct 4, 2006 10:19 PM
