Edge Boost Problems
Hey guys i am having a problem with my attitude monitor it will only read 39 psi of boost anyone else having this problem its the stock turbo but i know i make more than that in boost i got alot of fuel going probably to much, any help would be appriecated, but i think its time for manual gauges
The edge reads the MAP sensor and it is limited to 40 to 42 psi or in your case it is topping out at 39.
You are correct it is time for a manual gauge if you are making more then 40. |
Thanks For the help
