Dually Fender Flares?
I Have Seen Pics Of Duallies W/ Fender Flares On Them And Was Wondering If Any One Has Pics Of Them With Just Front Ones On. I Am Not Sure How It Would Look. Does Ay One Know If And Where They Would Seel Just Fronts? My Dualls Really Dont Stick Out Too Far So Im Not Sure If I Would Need Them. Thnx For The Help..
1 Attachment(s)
Bushwacker Pocket flares.
Did You Have Any Trouble Mounting Them? Did You Buy Just The Front Ones? If So Where?...thnx For The Help,..
I have been wondering the same thing....I am wanting to put a set on my truck as well....I know you can order just the front ones from certain places on the net.....
Originally Posted by jk6140
(Post 1882774)
They go on in about 10 minutes/side, but the Cummins badge needs to be removed or relocated. The fit is very good, and they seem durable (no rock damage at -30 and 200 miles of gravel). |
i only need the bushwacker extend a flares....my tires are not too much wider just a bit, i see that my dually fenders are getting a bit of a beating.....i finally found them on 4wheelonline.com, just the fronts.....
All the listings say that the rears won't fit duallies but apparently they do because there are a couple guys here with them.... Just FYI...
frieghtliner makes a pick up truck like the CXT and they use a dodge dually bed and ive seen them with fender flares on them going wensday and see if i can order a pair will let you guys know
