DTT recommended ATF???
Old May 19, 2006 | 04:27 AM
Dodgezilla's Avatar
I've read a couple posts where guys said DTT says to ONLY use ATF+3 in their transmissions. Is this true? I've spoken with DTT a couple years ago and they made no mention of this back then. Also, how much fluid will I need when I drop my DD pan to change the filter?
Thanks
Old May 19, 2006 | 08:01 AM
bchesley's Avatar
My DTT installer said to use dexron III. He said that the ATF+4 was too grippy a fluid for their setup. I asked him about Royal Purple and he said that would work too. I am changing mine this weekend. I think that it will take 7-8 quarts if I remember correctly.
Brad
Old May 19, 2006 | 09:01 AM
E-Train's Avatar
Atf +3
Shanti at DTT told me that some folks use Royal Purple, some Amsoil, some Red Line, and some use Dexron III. The Dexron is more prone to shudder in some Dodges. They recommend a good ATF +3 over +4 because it has LESS friction modifiers. Did mine about 2 months ago and it took 15 quarts (drained the TC). Make sure to tighten you front band too.
Old May 19, 2006 | 09:15 AM
Dodgezilla's Avatar
Thanks. The trans is brand new so I'm just doing the 1500 mile maintenance on it. If the band needs adjusting already, then I've got big problems.......
Old May 19, 2006 | 11:35 AM
fgrdods's Avatar
You should plan to adjust the bands. That's one of the reasons of doing the service at 1500 miles. There is a certain amount of break in, that should be expected. Talk with your builder. He knows...
Old Jun 12, 2006 | 10:08 PM
ckennedy's Avatar
AMSOIL is now ATF4 and so are others coming like schaeffers ??
Old Jun 12, 2006 | 10:16 PM
Ace's Avatar
Ace
The only difference between +3 and +4 is the base stock used. +3 is conventional, +4 is synthetic. They are both formulated to the same spec.
Old Jun 13, 2006 | 08:06 AM
BarryG's Avatar
Bill filled mine with dex at the rebuild. At the first service interval my bands did need a bit of adjustment. I refilled with amsoil and have been using it for the last 70k with no problems at all. I did notice that the dex was grippier during the shift. With the amsoil I did notice a little less grabby shift.
Old Jun 13, 2006 | 10:13 AM
BigBlue's Avatar
Mine told me ATF +3 for smooth shifts and dexron for firm shifts.
Old Jun 13, 2006 | 12:52 PM
genros's Avatar
Hey Zilla
I think tim suggested an atf 3. (ask him for assurance)
He also said you should check the servo pressure clearance (something like that) and the band adjustment. All this at 2000 miles
I am about a hundred over now. just waiting to get on my buddies lift. I have a small leak up at the gear shifter as well
Old Jun 13, 2006 | 08:07 PM
Dodgezilla's Avatar
Hey Genros, my original post was almost a month ago. I did talk to Tim back then and they indeed recomment DexIII. That's what I put in. Band adjustments seemed fine...
Old Jun 14, 2006 | 07:24 AM
genros's Avatar
cool
ill look at the dates before i respond
Pig
23
Jun 4, 2010 01:01 PM
PADuallyBoy
Apr 1, 2009 10:58 AM
dieselfan
Aug 5, 2006 10:44 PM
boostjunkie1
Jul 4, 2006 05:05 PM
Pig
Mar 13, 2006 09:12 PM
