DSS - 185 ft.lbs ?
Old Jun 24, 2007 | 06:48 PM
pet05's Avatar
Unhappy DSS - 185 ft.lbs ?
I am trying to install the DSS kit on my truck. It states to torque the NEW pitman arm nut to 185 Ft.Lbs. Unfortunately, I do not have a deep socket to fit that new nut that the kit comes with. I called Auto Zone, Napa, Sears and Ace and NOBODY carries one that deep.
I am figuring to just use an 1 1/4" wrench and tighten it down as best as I can. Mark it and watch if it starts to come loose.
How would one even torque that 185 ft.lbs without some type of impact gun??
Old Jun 24, 2007 | 07:10 PM
Pooter's Avatar
Leverage.
You can hit 140ftlbs pretty easy with a torque wrench due to the length.
Try a jack handle for a cheater bar.
Not the same nut, but when I reinstalled my stocker after replacing the pitman arm for my lift, I just hit it with an impact, hasnt loosened up at all.
Old Jun 24, 2007 | 07:48 PM
PourinDiesel's Avatar
I just used a LARGE adjustable wrench and propped my leg up against one tire and shoved away. ITS TIGHT!!
Old Jun 24, 2007 | 09:32 PM
pet05's Avatar
I think I will do the same. I have a large 1 1/4" open-ended wrench and I will put some leverage (my leg) on it and tighten it. I will mark it and check it later to see if it loosens...
Old Jun 24, 2007 | 10:04 PM
53 willys's Avatar
we have a 5 foot torque wrench at work for this kinda stuff
it's pretty big... almost funny big
Old Jun 25, 2007 | 10:34 AM
cquestad's Avatar
A large adjustable wrench...or a box end is EASY to hit 185 with your foot against the tire.
If your pitman arm has been on for a while it won't come off regardless of whether the nut is on or off anyways...lol.
Old Jun 25, 2007 | 10:39 AM
THURENfab.'s Avatar
I just emailed you back and suggested the exact same thing lol!!
Just use a cheater pipe as without it, you have to "jerk"( ) the wrench, and with the pitman shaft moving it's hard to get it really tight. With the pipe you can slowly crank it down good...
Old Jun 25, 2007 | 10:52 AM
Festus's Avatar
I just supported myself with foot to tire and pulled without a cheater bar. I probably overtorqued it. I haven't even had it cross my mind until seeing this thread and I'm not going to check it either.
Old Jun 25, 2007 | 11:20 AM
TX_Diesel's Avatar
Do the cheater and add a bit of loc tight. It won't come off. If your really worried about it, you can drill it and use safety wire. this is required to run a motorcylce on track. it would serve same purpose...
Good luck.
Old Jun 25, 2007 | 10:46 PM
pooperscooper's Avatar
I used a large adjustable wrench....185 is pretty easy with a 14-18" wrench or so. with a pipe, you are probably over torquein
Old Jun 26, 2007 | 11:07 AM
Need95-00CTD's Avatar
Yeah, with an 18" wrench you would need just under 125 lbs of pressure to get to 185lb-ft. Wedge yourself in good and start cranking.
Old Jun 26, 2007 | 01:21 PM
BigBlue's Avatar
I just used a 3 foot cheater pipe on a 16" breaker bar and just tightened it until I couldnt move it.
DieselDodd
Apr 9, 2016 03:05 PM
Jim5870
Jul 15, 2006 01:32 AM
JImbo1
Aug 27, 2003 08:13 AM
Davidp
Feb 1, 2003 05:49 AM
