Digital monitoring
I am buying a smarty and was wondering if there was an monitor out there that i could use to monitor my system. I did have a predator programmer and loved how you could view live data. I was informed that the smarty POD does not have this option. Is there any type of digital monitor out there that i could use to view the live data. Any information would be helpful.
Thanks |
Read up on the Quadzilla Commander or Scout, both are standalone systems.
http://www.thoroughbreddiesel.com/qu.../commander.htm http://www.thoroughbreddiesel.com/quadzilla/scout.htm |
The edge insight or the Quadzilla scout will give you a nice set of digital gauges. I went with the Quadzilla Commander(pre scout and pulse) because I can also change power levels on my Quad X2.
I had the commander with my first mega cab and it worked flawlessly. With my 2nd mega I went with the Scout as it has a ton more features and gauges.
Both are great products. Keep in mind with the Scout you wouldn't have to purchase a RP gauge as with the Commander you would. The Scout (as you can read from above link) stays plugged into the OBD2 port all the time so it reports pretty much everything your computer sees.. Good luck! |
