Cummins weakness? 325hp vs 305hp
Dump the oil, put some new oil in run it, fill to top notch. Depending on how long you drain the oil you might get different results.
Dodgetech77, The injectors are exactly the same 03 05 whatever only the nozzles are different. Those that modify the nozzles say the 600 series nozzles hole placement and angle is hard to beat. That is what I was getting at.
ks
ks
I have an 07 and will say I put 12 quarts of oil in every time and it fills her up guess chrysler put the 03-04 oil pan on my truck...must of had a couple on the back shelf covered in dust they didn't use in 03-04 so they snuck em on the newer ones when they could to pinch pennies
The valves, the way the oil is injected to the rod,s and the piston lubrication just to name a few. A lot of good info on you tube, there are four videos that look like factory made tech videos. There is a lot of detail and they explain the difference between the different models.
BigBully
Jun 28, 2006 04:47 PM
Huff nPuff
May 20, 2005 08:49 PM
