Cummins weakness? 325hp vs 305hp
Well the list is kinda long, but for starters:
fuel delivery is different. 305 lift pump is at the enigne, 325 is in the tank (except 04.5 models).
Turbos are different also 325 has electronic wastegates, 305 are manual.
I know others will continue the list...
325 ECM is faster and has more memory and more protective measures for truck. 325 torque management is harder to get rid of (scary larry). 325 Injectors are bettter design stock. 325 has three injection events, 305 two injection events, (third to heat the exhaust cat). 305 ....no cat. 325 rods are plastic
.....just checkin to see if you were paying attention. Some 325 motors in 05 had plastic end tanks on the intercooler. All 305 were metal. Al 305 had od lock out on the auto. 325 up to 06 had tow haul with no od lock out. Plus what everyone else said. ks
My opinion from having both.
305 gets way better mileage, and has better throttle response. 305 pulls better at lower rpms.
325 is alot quieter. And the new tow/haul set up on the 06 is better.
This is just from comparing the two trucks I had/have. But the 305 I had would run circles around this 06. Both with the same gears, and both with Edge EZ boxes.
It is not that I dislike this 06, but I miss the way that 04 ran. And the mileage that the 04 got.
question please
thanks,
david
socal
How significant is the difference in mpg's? Do the differences remain the same after building to 500hp? Once again I'm also looking for inherent weaknesses and what measures can be taken to correct them to determine which would be the best engine in the long run. Thank you for your input.
Originally Posted by BigBlue
305's get considerably better mileage than 325's.
