Confused 05'Ram changed the A/C compressor now codes p0243,p0480-
wastegate solenoid-thought I got the WGS plug wet which is next to the compressor,took the plug out soldered the connection(didn't switch wires) same codes-coincidentally both batterys went bad after changing the A/C compressor giving me the codes-Truck over-heated first time after about 5 miles cooled to norm in under 10 min. Can bad battries take out the WGS I only have 70k on the truck !!
