Clutches??????
South Bend here
I know there's going to be conflicting answers on this one. I tore my tranny up and clutch at the same time. Don't ask me how. Anyways the question is will a stock clutch hold in my truck with the upgrades i have? I've checked with different peolpe most of them said no; others have said yes. I do however tow trailers ranging from 5,000 lbs. to 30,000 lbs.
I installed a SBC OFE about 18 months ago and have been very happy with it, however I cannot speak of the other clutches out there. I performed the install myself with minimal problems. I also installed the upgraded hydraulics as the clutch spring pressure is higher and I was concerned about breaking the "ears" off the stock slave cylinder where it mounts to the transmission bell housing. As an afterthought I think I would have manufactured a 1/4 thick plate to install on the back side of the slave cylinder to prevent the flexing of the "ears" and possible breakage. Definitely have your flywheel resurfaced prior to installing the new clutch kit.
Well I got a Zoom 20231. I've had a lot of people tell me they were good. I had a SB clutch in there and put roughly 120,000 miles on it. The only problem was my tranny said no more and tore up the clutch disc facing the flywheel. Another reason I went with it was they could get it sooner than any other. I just haven't figured out what the 4 gold clips are for on the sides of it. I'll let everyone know how it turns out. I'm finishing it up tomorrow. The next task is getting my turbo straightened out. It's not spooling up like it is supposed to. And it's not building boost like it's supposed to either.
But to answer the question I have a South Bend Clutch Dual Disk 3250 and really enjoy it, I wouldnt recommend going with a single disk, stick with the dual disk especially if your towing. The dual disk can be slipped while a single isnt made to be slipped and its only around a hundred or so more dollars. The only gripe I have about mine it's slow shifting, but other than that it's a great clutch.
I must be mistaken then, I assumed if a clutch plate is made in Asia then it is made of Asian steel which we all know is inferior or are you just not aware of who and what their products are made of?
I personally like haisley clutches, usually you can find a pretty good deal on a used clutch around the for sale forums on here or comp d. There was a South Bend Dual Disc and a Haisley dual disc both going for around 1000 bucks over on comp d a little while back.
Listen Im not going to start a peeing match with you on this because with one click of your mouse Im out of here, but I can tell you he doesnt use China steel, and I can tell you this is a fact.
The same method is used by Southbend to test their own stuff and if any of their stuff performed that badly, it would be tossed in the trash instead of being sold to the customer.
There are lots of other countries in Asia that make these products and it is not necessarily China. The truth is out there and it is not that hard to locate.
I hate how every clutch thread on this site gets into these arguements. Im sure that no clutch company has a 100% US made product. The only advice I have for someone looking for a clutch is find one that suits your needs if your racing, slead pulling, towing or just your daily driver. Then hope it fits your budget. A clutch is only as good as the people who stand behind them.
I think it is also VERY important to know you are buying something of Harbor Freight quality when you are lead to believe it is Snap On quality instead
A clutch is an expensive purchase and one should get the highest quality product possible to avoid having to replace it again prematurely. I talk to customers on a regular basis looking for a South Bend clutch to replace the inferior made "V" product they were talked into purchasing on another forum.
I won't say Valair is a no-good company, but I wouldn't like someone secretly becoming a member of a forum they were once banned from and continuing to push a product without becoming an advertiser. With that, I wouldn't like it especially if that same person bashes a reputable company like SBC who has paid to advertise and who will help out even if it isn't their own clutch. To me it seems like Valair has proved to be sore losers at times, even if their clutches are good enough to be used.
To anyone that buys Valair, more power to ya, but I'd like to have someone who won't try to push me in one direction or the other or try to play a customer who loves their product when they actually are the company itself.
To me SBC has proved their worth simply by doing things the right way.
If you have to replace the clutch anyway, why replace it with a stock clutch? Spend the extra $$ and upgrade now, or you'll be kicking yourself the next time it goes out.
