Clutch Pedal
The clutch system is hydraulic and pedal height is not adjustable. Check the level of the hydraulic fluid in the clutch master cylinder. Make sure the master cylinder is securely attached to the firewall. Check the hydraulic lines and master and slave cylinders for leaks. You may have a failing slave cylinder.
cgmorgan06
11-15-2007 04:02 PM
