Check Engine Light?
Hey guys i am running the predator stacked with the puck and i keep having my check engine light come on. I plug the predator in and it says there are no trouble codes. When i press clear then the light goes off. I really do not know what to do cause i am not even driving it hard when the light comes on and i cant even read the codes. If there is anyone that has any suggestions to help me out with this it would be greatly appreciated.
Thanks, Randall
Thanks, Randall
Have you cycled the key 3 times leaving it on the 3rd time to see if the truck displays any codes? They'll be displayed on the odometer readout. I'm a code checking freak, I usually do it at least once per trip!
You are probably exceeding a safe amount of boost for your stock turbo and throwing an overboost code. Do like DaveB said and check your codes with the key trick next time the CEL comes on. My Predator won't read codes either. In fact, it does none of the advertised features except give me the awesome power.......
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
