Cat Delete Test Pipe Question
Does anyone know if there are some sort of clamps or boots to use to make the cat easily replaceable.? I'm worried about emmisions testing and dealer visits if I delete the cat but the way the pipes fit into each other would make it difficult to easily take out or put in. What about some sort of flex type pipe or fittings to make it a easy swap out as needed.
Those are what I use on the hole system , its a pain to take apart the ubolt type clamps and still have usable parts even in a shop , the flat bands are great & they come in galvinized & stainless .
what material is the stock exhaust? You could do it all in 4" v-band if it is stainless, but then you'd have some $$ tied up in vbands. But it would be clean and a quick swapout! Joe, can you send me a pic of your truck? I want to see how the 20 percent looks. My email is mkivbren@hotmail.com
Thanks!
Thanks!
For those who have done the cat test pipe.....how long does the process take of removing the cat and adding the test pipe?
I've already read that in order to get the cat off that the crimps where the clamps were at have to be heated up and then the pipe must be twisted off slowly. Exactly how slowly or how long does that take?
http://www.genosgarage.com/products.asp?dept=225
Be prepared with a good sawzall when you're ready to remove the cat (for test purposes). Otherwise you will fight with it for hours, and it's a dirty job. You may need to remove a frame cross member to reach the front clamp area. It made the job much easier on the mega cab.
FYI, just removing the cat and leaving the stock muffler and resonator (on mega cab) makes practically no difference in sound. On mine, nobody noticed and I'm not even sure I can tell.
I agree with many other opinions, there is no fuel mileage gain from cat removal. Any possible performance gain is negligible and will go unnoticed -- this has been proven with dyno results. It's just an exercise to test your patience, and you can also place the cat on moth ***** until you really need it someday. If given the choice again, I'd probably leave it on. I also notice more diesel smell if the wind is blowing toward the cab -- not bad, but occasionally more noticeable.
When my brother put my Corsa exhaust on he took a cutoff wheel and made two cuts on the stock pipe on either side of the joint. Then took an air chisel and spread it apart. You could easily put everything back together if you needed.
