Cam swap
Old Feb 8, 2008 | 06:50 AM
Bad-Duvall's Avatar
Cam swap
Ok im startin my bulid up Tonight and have some questions and will have more along the way.
1st what size dowl rods do you use to hold up the lifters? I know on C model its 1/2" is it the same?
Old Feb 8, 2008 | 07:33 AM
judge88's Avatar
i use 1/2 '' and then shave just a little in the ends where it goes in the lifter. also cut a slit in the bottom of the dowel.
Old Feb 8, 2008 | 11:50 AM
Bad-Duvall's Avatar
Anything eles to look for ar watch??
Old Feb 8, 2008 | 12:29 PM
judge88's Avatar
be careful with the journals pulling cam out and putting new one in. lube the crap out of the new one with assemly lube before installing. theres a crossmember that will have to be cut in order to clear the cam gear. either that or lift the motor up enough to clear it. make sure timing marks are lined up correctly when reinstalling. 00 to 0 from crank to cam. injection pump gear dosnt matter on a third gen. break in is 15 min @ 1500 rpms. you will enjoy the helix 2. one of the best mods i did to my truck.
etn550
Apr 1, 2010 12:12 PM
AH64ID
Jan 18, 2009 04:59 PM
Pride & Joy
Jan 21, 2007 02:10 PM
PeteRR
16
May 26, 2004 09:24 PM
