burnout problem
Old Apr 9, 2008 | 08:56 PM
kyle_truck_pull's Avatar
Exclamation burnout problem
before i put the tripple dog with crazy larry and my 64mm turbo, i could hold my truck by "power breakin", and spoil it up and when i let loose is wouldnt even stay on the road. it was crazy fast. but now im not sure if im having tranny problems or programmer issues or what. when i try to spoil it up i get the smoke out the pipe but no power. i can hear the turbo spoiling. not sure of amount of boost cause the outlook monitor wont read my boost right (only shows 32). any ideas? is my tranny slipping or do i have other problems? also when im cruising around 55-60 when i get in to WOT it still comes alive hard, on turns in the road it will come loose easy. thanks for any opinons
Old Apr 9, 2008 | 09:05 PM
Spooler's Avatar
Burnouts with a stock tranny is a no no. Your tranny is probably on it's last leg.
Old Apr 9, 2008 | 09:16 PM
smokin95's Avatar
My guess is tranny said enough is enough. Thats alot of mods on a stock tranny... like Spooler said its prob on its last leg...
Old Apr 9, 2008 | 09:37 PM
Ramtuff06's Avatar
It don't take long with a big lift and tires to burn up a tranny and that bully dog will do it, but don't ask me I went through 2 stock trannies before I learned my lesson.
Old Apr 9, 2008 | 11:44 PM
D45's Avatar
D45
Aren't you the same kid who also wants to "roll coal"...........
Old Apr 10, 2008 | 04:30 AM
how come my tranny doesnt slip a bit any other time? like i said at any other speed than a dead stop, the truck will turn in its track? i just didnt know if i was having spoiling problems or something. it smoke great when i hold it but then clears up like everything on the truck has been shut off.
Old Apr 10, 2008 | 08:09 AM
heykw's Avatar
The first gear clutches r gone.
Old Apr 10, 2008 | 08:10 AM
haloman's Avatar
I am guessing its a TQ management issue.
Old Apr 10, 2008 | 08:52 AM
Dan Marino's Avatar
haloman
agrreed - TQ management.
Try seeing if you can burn the tires a bit by starting out in 1st gear manually.
Old Apr 11, 2008 | 07:11 PM
TQ manegement? tell me more, thanks
Old Apr 11, 2008 | 09:36 PM
heykw's Avatar
yea me to TQ manegement?
Old Apr 11, 2008 | 10:42 PM
haloman's Avatar
It tones down the torque to keep from doing a burnout cause there is not speed input but wheel spin so it cuts power.
Old Apr 12, 2008 | 06:56 AM
heykw's Avatar
OK how do you turn it off?
Old Apr 12, 2008 | 08:19 AM
Stainless's Avatar
If you guys want to know how to turn Tq managment off with a bully dog just PM me and ill hook you up
Old Apr 12, 2008 | 02:50 PM
haloman's Avatar
Smarty takes care of TQ management
