bullydog wont unload out of my truck
Old Sep 23, 2008 | 01:14 PM
moparmatt's Avatar
well me and my buddy were wanting to try out my bullydog in his 06 ive tried about 5 times to take it out and it says it is sucsessfuly unistalled but when we go to load it in his truck it says vin mismatch how can we go about tryin to do this i also tried it in 2 other truck that were both 03s with the 250 hp motor...also i would like to know if we do get the bullydog in his truck can we just set his edge to stock or do we need to unplug the module? will the attitude still show readings and what tire size should his attitude be set at for running 285/75s
thanks matt
Old Sep 23, 2008 | 02:15 PM
Bud Kunz's Avatar
You have to set the tire size back to stock on the original truck as well to get it to unlock.
Old Sep 23, 2008 | 03:02 PM
moparmatt's Avatar
thanks...i didnt try that.. is the stock size 32.50 ?
Old Sep 23, 2008 | 03:22 PM
molalla1ton's Avatar
on 06 it is 31.5. . .
Old Sep 23, 2008 | 04:03 PM
surfram's Avatar
Can you give out any specific tuning information on the new E3 Triple Dog economy tuner? Does it increase rail pressure or is it only timing/duration? Other than the available power levels, does it operate exactly the same as the regular triple dog?
Old Sep 23, 2008 | 04:09 PM
chipmonk's Avatar
i was hoping it would be a downloadable tune for those who already have a TD.
Old Sep 23, 2008 | 04:41 PM
moparmatt's Avatar
well got it loaded in my buddies 06...was pretty sure it had aftermarket clutch the pedal was soft and clutch was grabby but it slipped bad with the bullydog...he bought the truck used so were not sure what clutch it has in it, or even if it is aftermarket, its a g56.
Old Sep 23, 2008 | 05:01 PM
Bud Kunz's Avatar
It stores whatever the stock tire size is so if you go into the tire size in the menu it will say change tire size or return to stock. Just do the return to stock to unlock the downloader.
It does not increase rail pressure. It functions like a triple dog in that you can switch the levels on the fly. It does not have the extra options for lights and accessories or the top two power settings like the triple dog has.
The economy tune will be incorperated as the tow setting in all future versions of the triple dog starting with V2.4.5 due out later this week or first part of next week on the update agent.
Old Sep 23, 2008 | 05:06 PM
chipmonk's Avatar
thanks Buddy, i look forward to trying it out and seeing if it gets me better mpg's than CL.
moparmatt
Jan 19, 2020 07:14 PM
s cesnick
Mar 25, 2008 11:31 PM
Zino
Aug 2, 2004 08:58 PM
